How to wire up 3 plugs (lights) on 3 separate switches
Stevenanto
Montreal Canada
Hi guys,
I have a challenging question for me and possibly a very simple on for you.
I have purchased 8 led shop lights that go into plugs (not hardwired) and also one into another. So i was planning on putting two per switch/plug. So one switch would turn on one plug which will have two lights. I would like to put three switches for three plugs in the same gangbox right by the door.
How would I have to wire the three switches to the plugs?
I tried to google but not luck.
i got this, but not certain
http://starfm.me/how-to-wire-3-light-switches-in-one-box-diagram.html
Im hoping that you guys can help out.
Thanks
Kaizen
New England
That schematic is correct. but how much voltage are you running on all of the lights together? planning on using 15amp circuit?
you can get fancy using 14-3 but in a small garage probably not much savings.
pattenp
Virginia - USA
That diagram is as simple as it gets as long as the power is coming from the switch box. If the power comes from the outlet boxes then it a matter of running three switch loops from the outlet boxes to the switches.
Stevenanto
Montreal Canada
I will be running this from my subpanel off a 15 amp breaker (i believe) i dont think I will add other plugs on the same circuit. they only take 45 watts each. here is a link of the lights i bought. https://www.amazon.ca/dp/B0739THBJN/?tag=atomicindus04-20
https://www.lowes.com/pd/Broan-Deco...MIlbfcxuvW3gIVUxh9Ch0IfQRqEAQYBCABEgIzO_D_BwE
The above is a triple switch in one package. The one I used has one terminal for the black input wire and then three outputs, one for each switch. There are variations so make sure the one you select does what you want.
lg
no neat sig line
wow that is amazing, I've never seen this, I'll have to check my local stores as I dont have lowes in QC.
Also, if the lights are close to one another, you can wire a split-tab duplex receptacle with 2 feeds.
I am not familiar with the term split-tab
Is this in a garage?
yes this will be in my garage
Stevenanto
Montreal Canada
Norcal
If the lights are cord & plug connected then GFCI protection is required.
larry_g
oregon
are you sure that this is for lighting or plugs and not fans for bathroom?
No I am not. That is why I said in the post "There are variations so make sure the one you select does what you want." Yes there are ones for bathroom fan/lights and others for just lights. You have to confirm your getting the correct one for you needs.
lg
no neat sig line
alfredeneuman
Fullerton, CA
... and GFI must be readily accessible so on the ceiling is out.
The options are to use a GFI breaker, or install a faceless GFI device ahead of the switches, which would add a gang to your box's count.
theoldwizard1
SE MI
If this is a new build, install octagon ceiling boxes where to are planning on plugging in the lights. Then buy these cover
Shiftless
East Bay SFO
I’m not an electrician, but I thought those covers are no longer approved.
406.4 Receptacle Mounting.
(C) Receptacles Mounted on Covers. Receptacles mounted to and supported by a cover shall be held rigidly against the cover by more than one screw or shall be a device assembly or box cover listed and identified for securing by a single screw.
This is how I learned it should be done to conform to code.
But honestly, for ceiling light receptacles which are hardly ever going to be touched or stressed in any way, I don’t see a practical reason why the simpler octagon plates wouldn’t be OK if an installation wasn’t subject to inspection. :)
alfredeneuman
Fullerton, CA
1 combination that was UL listed (as an assembly) was the Leviton 5042, but they have ceased production, so Shiftless is right :thumbup:
mrpizza
IL
That schematic is good. I recommend one of those splice blocks for your grounds, you have to join the 3 switch pigtails plus three runs to the outlets and your incoming ground. Same for the neutral. A wire nut will handle the hot pigtails to the switches.
mrpizza
IL
I thought if the outlet was over a certain height that gfci wasn't necessary?
