Marctrees
Ideally the sw would be mounted so the chain hangs straight down, not to the side.
If you got the Sw shown in the photo, yes, it does lead out over a large chamfer, so either orientation will be OK, but vertical still smoothest operation.
All depends on size and shape of the little j box you will be mounting in.
But ya, of course you know to keep all wiring within the j box.
Step bit of course best way to make that size hole in sheet metal.
Orange wire nuts.
Lead the tip of the stranded like 1/16" ahead of the solid into the wire nut, then Pull on the stranded to check after you put nuts on.
Ideally, be in ball chain as you lead out through a new accurately placed drilled hole in the plastic vent cover, then change to string.
I have a good Attorney on retainer, so I can say this.
Marc
Orange wire nuts.
Marc
