This is what I do, for when I want a screwdriver type set up vs a ratchet or ball end driver or just plain hex key. I have two Wiha screwdriver handles, one regular and one stubby. They accept all 1/4" hex bits, and I have a good assortment of bits, including Wiha sets of allen, torx, and both of those in security type, too. Plus an assortment of Phillips and square drive bits. I do anything I can to avoid slotted, but I have them too.How about using either a locking socket driver handle or a locking multibit screwdriver handle with replaceable hex bits?
No you can't do that when you cut them the shank thats left will be larger in diameter than the ball end.You can always buy a set of ball driver and cut the ball end off.
Yeah I doubt anyone is using oversized hex stock to make ball-end drivers. I just measured my Bondhus ones and the shanks are all the correct hex size above the ball ends.Are you sure about that? Every ball end L-shaped hex wrench I own is the same diameter so you can use the other end as a regular hex. It seems logical that whatever grinding jig they use to make those L-wrenches would be used for straight wrenches as well.
Of course, it might seem like the hex stock is oversized if one were to just cut the ball end off and neglect to clean up the burr.
CoogarXR said:Xcelite makes a non-ball set too. Seems like I just saw a set on eBay.
ding! ding! ding! we have a winner!
Yes, they were made by VACO, but there are only a few onesie-twosies currently listed on Ebay. (VACO was acquired by Klein in 1986, but I am not seeing anything like what you're describing on Klein's website. Maybe I'm not looking in the right place.)
Most of the Xcelite sets listed are the type with a whole bunch of bits and a single handle, but here's a set of one-piece hex drivers:
https://www.ebay.com/itm/192718495073
there are a mess of different sets listed:
https://www.ebay.com/sch/i.html?_fr...sacat=0&LH_TitleDesc=0&LH_TitleDesc=0&_sop=15
I'd imagine one PB Swiss costs more than a whole set of cut down bondhus balldrivers (even if you had to pay someone to cut them!).
https://3989ac5bcbe1edfc864a-0a7f10...rackcdn.com/bondhus42/literature/HandyHex.pdf
Would these by Bondhus work for you?
View media item 85867
View media item 81328
Yes but they're the only ones I could find. Even Snap-on doesn't have them without the ball.
You got a link for that German one?
Sorry, but I ordered mine from Amazon Japan marketplace a while ago (I'm in Japan). It's listed as "currently unavailable" at Amazon US.
If it's hard to read the model number in the picture, it's 400QR. Hope that helps in your search. Good luck!
How do you like it? I just ordered one from KC Tool for use with a Nepros 1/4” stubby ratchet. The mating square on the Nepros is so tight that I had to knock my Felo spinner handle off with a hammer.
I see they are available in SAE and Metric. Do you know who makes them for NAPA? What is the handle surface like ..... hard, soft , in between?
Seth
you sure about that? back set is non ball...
I checked the 2018 catalog and they're not there. However, my 1995 catalog has your set in there.
When I cut a worn one off from my Gearwrench sae socket set I no longer could use it for it's intended size. It would how ever work for the similar size metric one.
