QuickJack - How do you store the frames?
PeterN
FDL, WI
I've got the QuickJack 7000 EXT and am looking for a secure way to store the frames either vertically or horizontally. Each frame weighs nearly 100lbs so I want to make sure it is stored securely. I'd be attaching the frames to a wood wall so concrete anchoring methods are not possible. Any pictures out there showing a good way to secure it to the wall?
rmsg0040
Toronto
Quickjack 5000 stored on the wall with j-hooks from the dollar store using tapcons
For your situation and the weight of each, store them vertically with chains looped around them
<a data-flickr-embed="true" href="https://www.flickr.com/photos/151400936@N07/44252653480/in/dateposted-public/" title="20170325_151425"><img src="https://farm5.staticflickr.com/4906/44252653480_4f74b06a1f.jpg" width="500" height="281" alt="20170325_151425"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/151400936@N07/45344420514/in/dateposted-public/" title="20170325_151743"><img src="https://farm5.staticflickr.com/4812/45344420514_8222783ed8.jpg" width="281" height="500" alt="20170325_151743"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
FULLSCALE302
Definitely store them vertically, it'll save your back for sure. I'll try to dig up a picture of the bracket I made for mine.
mikec35
NC
Good timing on this question. My 7000std's arrive on Thursday. I am going to store them vertically between my 2 garage doors.
Paycheck
I store mine on the floor under the car. But then I only have a one car garage.
428PI
Peabody, KS
Under the car for sure. I use them every weekend or so it seems. Leave them hooked up too.
Volcrew
I made a frame for the top of my 20T HF press frame. The frames hang on the sides and the rubber blocks are stacked on top.
Colin Len
Long Beach CA
I put some J hooks into the wall - one for each frame. Since the hooks screw into the wall I rotate them vertically to put the frames in place then turn the hook so it's horizontal and locks the frame in place so it doesn't go anywhere. I then have a bungee cord on there just in case. So far it works pretty well, was really easy and really cheap.
Ray-CA
San Diego CA
I picked up some Craigslist cheap mechanics creepers, removed the padded platform and store one lift on each creeper. I roll them under the tool bench and completely out of the way. The hoses are draped over a plastic hose hanger and the power unit is in a nearby cabinet.
Ray
paul337
Colin Len
Long Beach CA
^Fantastic idea. Now why don't they sell that here in the US? Looks like there may be some comparable options though.
Killer95Stang
I
I purchased these brackets from HD for $35. I then used a scrap 2 x 8 to mount the brackets to the wall, hitting at least three 2 x 4's in the process for strength. The QJs hang about an inch off the ground.
Colin Len
Long Beach CA
^Not as cheap as the other solution but not bad considering everywhere else sells those for $50. I think I'll bite the bullet and pick these up.
