Bigblue&Goldie
Steps look bitchin'!
What's this 600N you mention?
Looks like a hell of a shop. just so you know , when you are ready to move to AZ. I will be sick that day LOL.
Step turned out freakin' awesome Cam.
Yep, have to agree with Mike....
See, aren’t you glad now that you didn’t go with the off the rack tube ones..... Of course since we had to “Jeep Shame” you into the project we (the collective posters) get to take credit for how good these turned out! [emoji14]
Sent from my iPad using Tapatalk Pro
Thanks Pat. You've got a 175?, those are so badass. What are your plans?
I had to laugh when you said in your thread ya was a professional PD hunter. But I should have know better by now, you don't mess around, when you do something-you do it 1000%.
Couple years back my kid rolled my Denali. 6.0 AWD and four wheel steering. Everything for the drivetrain is good to go, just the body got Fd flat. Been looking for an ole school body to drop over it and not long ago was driving up in the high desert and came across a M175 for sale. Went back the following day with some cash and it was gone already.
But I like the sounds of what you got planned, way more fun![]()
I enjoy P-Dogg'in more than most. My Shooting Partner and I spent 9 days total training with Marine Corp Scout Snipers through Barrett's Long Range & Precision Schools between the mountains of KY and the high desert of NM honing our craft. 2 years ago we had to show our credentials to shoot P-Dogs on an organic beef ranch in SD...over the years we have been asked to come back to a few places to keep the population in check and some places totally get rid of them.
Now that would be an awesome experience
Mom and the pups, 525 yards, Savage 12 LRPV 22-250, Nightforce 3.5-15 x 50mm...the guys even made me some "Death from Above" cards so "Charlie" will know who did this...LOL...
Looks good Cam.
I can’t tell in the picture but are you tying it in close to the frame rail? I’ve done one in the past where the guy didn’t want a full blown bumper do I drilled out the plastic bumper and fabricated a mount for the pivot that bolted to the frame rail. Just a thought.
Too bad you can't use a bit larger sleeve and incorporate tapered bearings into the pivot. I prefer to use them as they do provide the ability to add some preload to the setup to compensate for clearances. Also like you have discovered, it is very difficult to built this as a complete bolt on using the factory rear bumper due to the lack of real estate to tie to a solid structure.
If anyone can figure it out though Cam, it will be you. Keep the pics coming.
Thanks for the vote of confidence Mike, much appreciated my friend. Now if only I could fool myself into that.
I like the tampered bearing idea though, maybe next time. If it wasn't for the fact that I'm now on the short end of the stick with our bartering deal, I'd have built a matching rear bumper. That might have been easier to create a move rigid structure for the mount. I was trying to stay clear of anything that would screw up the finish on the bumper as I didn't want to put any effort into it. Ive been battling a major cold over the last couple weeks and haven't been able to keep a clear thought. But yesterday it hit me like a ton of bricks just how ****** the overall look will be if I don't coat the bumper to match everything else...duh! I could have saved myself a little work had I not leaned towards the lazy side from the get go.![]()
Hey, I know what it's like pushing through not feeling up to par and your head in a fog. It flat *****. Deadlines don't give a **** about not feeling well. Hope you get feeling better my friend.
I actually kinda dig it vertical, will be more practical. They do look great horizontal but from the side look odd since the tire is usually driven out so far for clearance. Can try lowering the mount for the jack down below the swing out arm a bit to get the top of the jack below the roofline a bit more. Maybe dropping the baseplate down to the level of the bottom of the tire or so would give it a more proportionate look. Just shooting ideasSo believe it or not I'm at a crossroads again on where to mount the jack. I mocked it up in the vertical position and I'm not exceptionally digging it. But from an access point it's great. If I mount it horizontally one of two things need to happen. One, it goes up pretty high to clear the tire rack. Or two I push the tire rack out like 4" to create enough space behind it. Just one consideration, the owner is no spring chicken so I'm concerned about going to high.
Anybody got some input? Thnx
I actually kinda dig it vertical, will be more practical. They do look great horizontal but from the side look odd since the tire is usually driven out so far for clearance. Can try lowering the mount for the jack down below the swing out arm a bit to get the top of the jack below the roofline a bit more. Maybe dropping the baseplate down to the level of the bottom of the tire or so would give it a more proportionate look. Just shooting ideas![]()
Hey Cam, I actually found a couple of better pictures from when I built it 7 years ago.
Here is the actual bracket that bolts to the main tire carrier.
Hi-Lift jack fastened in place.
A better picture of it in the closed position.
Sorry, didn't mean to hijack your thread with my pictures bud.
I was hoping a boot to go over the mechanism would be brought up. Seems like the back end of off-road rigs get plenty dirty and you know how that ends up with a hi-lift jack.
Also, I like the vertical mount as I think it is easier to load and unload if it is not angled. Less dinged body work and fewer smashed fingers if you just need to go straight up and park it in the holder.
I think the bottom of the holder should align at least with the departure angle though so it isn't low point in a bad situation.
Cam, I like how Mike has his. My dad's Rubicon has a WARN bumper with the jack mounted vertically with the foot hanging over the edge of the bumper and we've bent the **** out of it hanging it up on rocks.
Cam, one more nugget for thought. You mentioned keeping it about 2" above the receiver hitch. If the owner plans on using his receiver to tow a small utility trailer that low may interfere with the latch on the trailer coupler. The TJ I built the bumper for last summer had that exact experience with his OEM bumper and tire mount, he couldn't latch his trailer coupler. He had asked me to give him 4" between the top of the receiver and the bottom of the tire.
You are correct that it moves the tire up and blocks the rear window but they are pretty much useless with anything over a stock tire anyhow.
Again, just a thought.
Ya I thought about that but as much lift as it has he'd need a solid 6" drop hitch for a normal trailer. I'm also going the offset the tire mount to the receiver so it can sit low or be flipped 180 degrees to set high.
And just so ya know Mike. While I was at the docs office this morning I sent the owner your pictures. He literally just let me know as I was typing this response he wants it diagonal. So a total win my friend. Thanks again.![]()
Glad to be of assistance Cam, but sorry it ended up in more work for ya bud.
