http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=200343610187
This thing is cheap. Is there anyway to remove the small container and replace it with a larger cylinderical container? Or are these things generally non-removable? Look like it might be missing the lid?
Like I said it was cheap for an ultrasonic cleaner.
...edit....
Just found this from the manufacturer website:
I wonder how big a cup you could use?
Like I said it was cheap for an ultrasonic cleaner....edit....
Pulsed Ultrasonic Cleaner
Several times more powerful than similar devices, PUC dislodges dirt left behind by ordinary ultrasonic cleaners. Although very compact (the well is 8 cm diameter by 3.5 cm deep), PUC creates maximum turbulence by combining a subsonic wave and a high intensity ultrasonic wave. The well will hold small microdissection instruments. Insert the plastic cup in the well and triple the volume available for cleaning. It contains a dual setting for normal or high power and shuts off automatically after 5 minutes.
