Cheap Air Compressor Sound Insulation
Urambo Tauro
SE Michigan
Just wanted to share a quick dirt-cheap solution I came up with to help reduce air compressor noise.
Got a little old Campbell Hausfeld FL-3001 that I've tucked away up in the corner of my garage, right on top of a big shelving unit. It has wheels, but I have no intention of taking it mobile, so I slipped some leftover rubber bedliner material underneath to serve as bushings to help against vibration. I also drilled through the top of the shelving unit so that I could wrap a zip-tie around the foot. It probably wasn't going to roll around anyway, but this ensures that it won't.
I once worked at a place that had built a booth/room around their shop compressor, and always liked that idea. But I wasn't quite prepared to do anything that fancy, so instead I grabbed some spare cardboard and cut it to fit around the compressor, boxing it in. And instead of proper insulation: bath towels (I told you this was cheap haha). I stapled some old towels to the inside of the cardboard panels and mounted them in place, leaving holes for the wiring and hose.
It works pretty great! Of course I can still hear it, but I can actually hear myself think now when it kicks on, and I don't have to wait for it to turn itself off before continuing a conversation. I can barely hear it when I'm out in the driveway and the garage doors are closed, and from the house I can't hear it at all.
I'm looking forward to upgrading to a larger compressor at some point, but at least this one's a little more tolerable to live with for the time being. I had the scrap materials on hand, so it didn't cost anything but time. And of course I can still take the panels off every once in a while for draining and such. Totally worth the effort.
brownbagg
google sound air compressor, there a gut that took an air cleaner from a junk yard and it killed 80% of the noise
i think its on youtube
U
Urambo Tauro
SE Michigan
That is going to cause the compressor to overheat in the summer.
Maybe a small roof vent is in order, then. The roof has air flow coming from the soffit, but I can imagine this trapping hot air around the motor. Adding a small vent would allow continuous air flow through there without being open to the interior of the garage.
Dan in Pasadena
Pasadena, CA
Definitely better, but not hugely better. At least to my ears. Still could use some kind of enclosure with a cooling fan to truly make it dramatically quieter.
rayra
Escaped from Los Angeles
egg-crate-style foam does a real good job. I built a cabinet for my compressor and used pegboard to facilitate some air flow. while still blocking most of the noise.
I made the front door 5.5" thick and full of shelves on the inside, full of all the air tools and accessories, and that makes a pretty effective noise blocker too.
Some 1" egg-crate foam will probably get added to the inside of the door.
U
Urambo Tauro
SE Michigan
That's a nice cabinet, perfect fit! Good use of space. If you have room for foam, that should help cut down on any echo chamber effect.
