When it does, it clicks every second and the Aux Heat light flashes until I turn it off at the thermostat. It did this a few times about a month ago after it was switched over from Heat to AC so I changed the corroded contactor. Also changed the run cap and installed a 5-2-1 hard start, cleaned condenser and checked wires. It's been ok until today when it clicked on/off again. Turned it off and turned it back on a little later and it started ok and has been working fine for the last five hours. System is 25 years old, a Tempstar 2-ton with a Goodman compressor. I'll change any other relays, sequencer, whatever to see if it helps. I'm changing the cap for the blower motor today; maybe it's out of spec. Any suggestions would be greatly appreciated.
