Ultrasonic Cleaner Demo
9GUY9
Mankato, MN
There were a few people asking how well the HF $80 Ultrasonic cleaner worked, and I was sitting around with nothing to do. SO I decided to clean a few sockets I had brought home with mine. I grabbed a beer, my camera, and the bag of old sockets I brought home from work and went to the garage.
Heres the collection of old USA made (and several bench top) sockets I found at work while digging through the extra socket box.
They were pretty old meaning the grease packed into them has been there for some time.
Sockets on the basket in the cleaner.
I filled the cleaner about 1/4 with a purple cleaner. I don't know the brand, but its pretty strong stuff. Filled the rest of the way with tap water.
I used a old hand cleaner container to get the water. THe cloudy white stuff is dried hand cleaner. I didn't take it out because I figured it would be a little extra cleaning power:)
The Chicago Ultrasonic cleaner has run time options of 90 sec, 180 sec, 280 sec, 380 sec, and 480 sec. It also has a heat function. I really wish it had longer time settings. I always use the 480 sec time with heat.
Heres what it looked like after 2 8 min cycles.
A little vid I took of it working. The mic on my camera was not liking the ultrasonic sounds.
After about an hour and several cycles the temp was 111.8
To be fair I started with every thing at around 40 degrees. This beer is room temp:beer:
After about 5 or 6 8 min cycles and a little over an hour in the cleaner I removed the sockets and rinsed them with tap water. The results
You can see almost all the dirt and grease was removed. The dark areas are mostly rust.
I searched my garage and bike room high and low looking for more dirty/greasy stuff and couldn't come up with much. My OCD has me cleaning my tools after each use. So heres the dirtiest stuff I could come up with. A CMan Pro screw driver with a couple years worth of oil film on the rubber handle, a couple old bolts, and a pulley from a old bike dreailuer. The pulley was pretty caked with grease, but it is a wax based chain lube I use.
I used the same solution as the sockets, I just topped it off with more purple cleaner. After 2 8 min cycles with heat. And a rinse with tap water.
I was surprised to see the pulley come out spotless. THe screwdriver felt like new (minus all writing on the handle:(), and one bolt was clean and shiny, the other clean and rusty.:)
I bought the cleaner for cleaning bike chains, which it works excellent for. The cleaner really gets all the dirt and grease out of all the links in a bike chain. I would not use it to clean heavily caked on grease from parts. But for cleaning tools shortly after use I think it would work awesome.:thumbup:
autoace
Maine,USA
Great! I have some older socket that the bits of grease don't seem to come out of, looks like the cleaner might do it. thanks for the demo.:thumbup:
autoace
Maine,USA
Merk. may be tempted to goto HF and get one. He could make Snap-on socket stew! Nice and clean!
compman25
Spokane
How do you know that the cleaner itself couldn't get them that clean just soaking for the same amount of time?
Bull
No way. I have cleaned a lot of old nasty sockets, wrenches, and ratchets. If you let parts just sit in solvent, even for a long time, you still need to manually agitate with a brush to get them clean. This thing looks like it eliminates that step.
The writeup is great, absolutely 100% what I was looking for. How come you say you would not use it to clean caked on grease on parts? You mean parts that have an inch of caked on mud on them I assume, as opposed to a very dirty wrench, for example?
9GUY9
Mankato, MN
I have soaked dirty items in this cleaner at 100% purple cleaner over night. It certainly makes it much easier to clean, but I have still had to use a brush to physically clean the dirt/grease off.
Busted_Knuckles
Northwest Illinois
Just a thought for the guys who don't have one yet, and plan to go shopping, the timer on that thing will be your first complaint. Its nice to drop tools in one and then walk away and go do something else, having to reset it every 8 minutes will get old fast. Mine never ran for less than at least a half hour. I'm perplexed as to why they would make a cleaner like that with a timer, unless is design purpose was for a material that would break down if left in too long? otherwise, I don't get it?
9GUY9
Mankato, MN
the timer is my biggest complaint.
I think this cleaner was never intended for heavy cleaning. It was probably designed with jewelry, medical equipment, and things similar that do not get really dirty. The heat function can be turned on without the timer running, so you can get the solvent heated up and "cook" it for awhile.
jshillin
PA
Wow, that did a pretty good job... I might just have to pick one of those up. I was looking at getting a tumbler, but might go this route instead.
bmwpower
Thanks for the demo. Someone has to hack the timer. Too bad it's not an egg timer style.
crankshaftdan II
Milwaukee, burbs.
Re: Ultrasonic Cleaner Demo vs paint shaker type
Same note in regards to HF, local stores here are closing out their paint shakers for $39.00 if anyone is interested for making a one gallon plus super shaker cleaner. Will probably be very noisy compared to the ultrasonic cleaner, but faster for tool cleaning???:evil:
Bull
Thought of another question: How loud is that thing when it is running? The audio on that clip is kind of hard to use as a guide.
I looked at eBay for ultrasonic cleaners earlier. There are a lot of options...some having timers that can be set for much longer than 8 minutes. But they start getting pricey. Decisions, decisions.
9GUY9
Mankato, MN
Its not very loud. Its a quiet buzzing sound, when i had it full of sockets they were making a little more noise. I would compare it to a cheap fish tank air pump sound.
krehmkej
Oregon
I just picked up a HF cleaner. Used it to clean cartridge cases before loading. Makes a very faint buzz sound. Probably inaudible from 4 feet away.
Danglerb
SoCal
I have both of the cheap HF IR temp things, $10 and I forget what the $30 one was on sale, but both work great within the ranges they check. For air or water you may need something you can stick into the flow etc, or you might be measuring a distant wall or other object behind the air/water.
sjt78
Western NY
Thanks for the demo! It was educational even though I have a commercial ultrasonic cleaner (got it for $7 at an estate sale of a former dentist). Mine is small though, probably only 6"x6"x6" at most. Anyway, I never even thought about using it for my bike chains. Excellent idea. I always dread cleaning the drivetrain on the bikes and probably leave them dirty for far too long due to it being such a chore. The less I have to manually clean the better for the bike. I usually use mine for OPE carbs, cleans the dried up gas and crud real well with just using simple green. Just as reminder to anyone reading these posts, NEVER put any flammable liquids in the ultrasonic cleaner. "Biodegrabeable" cleaners work just fine and are safe to use.
jjarrell4
The Ol' Dominion
So did the purple power take off the writing on the CMAN screwdriver? or did it come off when you wiped them dry after the clean?
Just curious
9GUY9
Mankato, MN
How do you like that little IR thermometer? I searched and found it sells for $24.99.
sorry it took me so long to reply, I missed your question. The thermometer works pretty well. Its actually from my Nitro RC car days. It has come in handy for several other things since then. I think I payed like $20 for it 5-6 years ago.
Bull
Damn, that price is attractive. I'm a little bit concerned that I will immediately wish it was bigger, though. Can't fit a long ratchet or wrench in it.
9GUY9, has the size ever been an issue for you?
9GUY9
Mankato, MN
size has always been a issue for me. I have learned to make the most of what I have.:)
mjozefow
Lafayette, IN
I have had three of these things.
BUY A GOOD ONE!
The cheapos only serve to get you hooked on ultrasonic cleaning technology. My current unit set me back $800 and has been worth every penny. If anyone needs something cleaned hit me up!
Another thing, if you are going to only be cleaning sockets and such, a USC is probably not worth the money. But for carbs and various engine parts, they are indispensable.
Here's mine:
Bull
Holy smokes! I'd love a large, quality unit, but $800 is way more than I am going to drop. I'd have to be making money with it to justify that purchase.
On another note, I deleted your double-post but now realize there was an additional pic in it, of two carbs. Sorry for that. :( Was that pic showing a before and after?
mjozefow
Lafayette, IN
Fixed it, my bad on the double.
I clean carbs and stuff for money, the unit has almost paid for itself. I've had it ~6 months.
http://tippecanoe.craigslist.org/mcy/1547335673.html
Bull
Well, we can never have too many before and afters. Would you be willing to do one with your bad-boy? Maybe a rusty wrench, with some vinegar added to show the derusting powers?
Is it wrong that I really love taking old, dirty, rusty tools and cleaning them so much? I gotta get some kind of cleaner!!
mjozefow
Lafayette, IN
I'll be in Massachusetts, but I can get more carb pics up. Maybe I'll try to swing by your neck of the woods.
Bull
How long is that HF unit on the diagonal...the basket area I mean? I want to know what is the largest item I can fit inside.
Danglerb
SoCal
These are great items to look for in school or industrial sales, just make sure they work, and you might get a nice big unit cheap. One of my friends is trying to work a deal on a ex aerospace unit big enough for a V8 block.
