Best power tool for general wood cutting?
CC268
Best power tool for general lumber cutting?
Alright, don't make fun of me too much, but I never learned how to do much woodworking growing up. The only power tool I own right now is a little 12V drill ha.
Is a circular saw the best cutting tool to buy if I want to build some wooden work benches? Or is a table saw more useful for that?
Thanks
:bowdown:
danielbuck
I'm not really a big wood worker either, but If I could have only one woodworking tool it would probably be a table saw. I think with home-made jigs you can do most of your cutting on a table saw.
ddawg16
S. California
A compound slider miter saw will be your best overall tool to start with.
You will be able to cut boards up to 16" wide.
You will be able to use it for cutting molding....and crown molding....
It takes up only a small amount of space.
Portable.
Next.....you need to work on your batch of cordless tools.
Forget that 12v ****.....
Unless you like spending money on tools....that you don't make a living with, the Ryobi 18v series of cordless tools is by far you best value.
Keep an eye out for specials for their combo kit.....typically it will be a drill, 7 1/4" circular saw (great for ripping plywood), Sawzall (great for cutting tree limbs), and a cordless vac or light.
All my cordless stuff is Ryobi....I have 4 Li batteries that will recharge before I've discharged the next one.
dogdog
2manytools
Mt Pleasant, MI
I wouldn't reccomend a table saw for many of the cuts you will probably be making. Table saw is geared towards sheet materials & rip cuts (cutting with the grain on long boards, like a 2x4). If you are making lateral cuts on a 2x4, you are potentially looking at some safety issues. That's where a miter saw would come in useful. That would allow you to make angled cuts, much more easily & accurate than a circular saw.
A circular saw is good for cutting sheet material & cross cuts in dimensional lumber. It will do beveled cuts as well, but again if you need make angled cuts, it won't be the easiest task.
Tallpilot
Orlando
When I hear wood I think of trees and chainsaws. When I think of circular, table and mitre saws I call that lumber (even though it’s wood from trees).
LX-Markham
Markham, Ont.
Circular saw is going to be the most versatile for rough woodwork. Good place to start and a must have IMO. Not going to do fine woodworking, but it's fine for your workbenches.
Saws, in order that i purchased them in (over decades, LOL):
  • circular saw
  • miter saw
  • jig saw
  • reciprocating saw
  • table saw
Sturdy contractor table saw is the best purchase I have made. Would have preferred a fixed unit, but I need it to fold up and be put away.
jives
Central NY
Start with a good circular saw. Build a bench. Then put a sliding compound miter saw on it.
^^^This is the ticket. Add in the straight edge guide. If money is an object, buy a used corded circular saw of a quality brand. Milwaukee, DeWalt, Makita, Skil (professional), Bosch. It will last the rest of your life and will always work (unless you cut the cord. . . .)
LB-1911
Northwestern Il.
Re: Best power tool for general lumber cutting?
Thanks
:bowdown:
Once you get a circular saw you'll want to make one of these -
How to Make a Circular Saw Guide - This Old House
Pick up a Swanson® Speed® Square
Circular Saw selection........ Another topic.
:beer:
C
CC268
Portable.
Thanks! Yea Ryobi seems to be the way to go. They have a nice miter saw and table for like $250
engineer2
Chicago burbs
Back when I was starting out, I did it in this order
Hand saw
Jig saw
Used circular saw
miter saw
table saw
I got by without a table saw until I got into home remodelling projects.
PFSard
Mesa, AZ
I built my first workbench with a circular saw. I wouldn't spend money (as an initial purchase) for a decent table saw unless I had other projects in mind.
Given the availability of used tools today, I might buy a quality brand, lightly used, corded circular saw.
Good luck with your workbenches. There are a bunch of threads on GJ of workbench builds. You might want to search for these for ideas and suggestions.
C
CC268
Thanks. Even the nice circular saws are fairly cheap. Seems to be a lot of cordless circular saws, but I assume corded is the way to go.
Looks like you can pickup a nice Milwaukee/Makita for $125 range.
Plan would be to make the EAA Workbenches.
bczygan
DETROIT! Arsenal of Scrappers
Thanks
:bowdown:
What is your budget and what type of bench fit and finish? Are they to be rough 2x4 and plywood or cabinet grade?
That will determine the answer.
Bill
Edit: Just looked at the EAA plans. It seems a halfway decent circular saw, straight edge and an accurate square would do the job with careful measuring and layout.
Bill
C
CC268
Are you planning to build an aircraft?
Bill
There may be a possibility that I build something like a Vans RV-14 sometime down the road.
The EAA workbenches are a good example of things I would like to be able to build though.
I'm essentially building a tool collection from scratch at this point and enjoy the feedback I get from people on here.
icthruu74
If I could only have one saw, it would be a circular saw. That said, I use my sliding miter saw for the majority of my cutting needs, and reserve the table saw for ripping or sheet goods.
f121
UK
If you plan on picking up 18v cordless tools, then a cordless circular saw is very good. Ive got the makita and used the milwaukee 18v cordless saws and both are brilliant. I only own a cordless now and don't feel any need for a corded one.
Fwiw, I agree with the above, if you're only buying one saw, get a circular saw. I would maybe consider a track saw instead, not used one but the reviews are great. After that a mitre saw is a great way to spend $100
C
CC268
Ehh...if I'm going to get a circular saw I am tempted to go the corded route.
Hilltopmasonry
I used to believe that as well however I recently purchased a Dewalt 60 V flex volt saw and I am totally impressed with the power of it. It will hands down out power my corded circ saw.
I doubt I will ever pull the corded saw out again
shoot summ
You wont go wrong with a worm drive skilsaw, it's a tool that will last your lifetime.
While I have a cordless circular saw, I bust that skilsaw out first everytime, it's an absolute joy to use.
Guys used to frame houses with only a Skilsaw, you can do a lot with them. A miter saw is nice too when you get to that point.
I think your 12v tools are fine, my goto drill/driver/impact is a newer 12v Dewalt set. They are small, light, and plenty powerful for most everything I want to do. I can bust out the mongo 18v stuff when needed, which isn't very often.
C
CC268
Yea that Skil 77 is sweet.
clarence35
LA
The answer really depends on what kind of woodworking you want to do in the future, and how much you intend to spend on woodworking tools in the near future. If you're buying power tools only for the workbench you need to build now, the circular saw is probably the cheapest tool that will get you nice results. However, if you want to build more complex projects such as furniture, like another poster said, the contractor table saw is by far the most used woodworking tool in my garage. It's often the fastest and most accurate tool for most projects except for cutting down large plywood sheets, flattening or straightening lumber, or cutting curves or trims. But the cost is high enough ($500+) that I would not recommend getting a contractor table saw until you're sure you like woodworking. And many people don't recommend getting a cheap table saw since it may nullify the main accuracy benefit of getting one in the first place.
If you do choose to build your workbench with a circular saw (a good choice for sure), I would not recommend buying something too expensive. Since anything that needs accuracy gets cut on the table saw, I only use my circular saw to rough cut plywood sheets, which then get cut to specific dimensions on the table saw. For this use, I have a $13 (refurbished) Ryobi corded circular saw that gets the job done perfectly well. The only reason I can think of to buy a premium circular saw is if you are a contractor on jobsites and need the durability. For many woodworkers in a shop, the circular saw is not regarded as a tool for accuracy, so I don't see the value in paying a premium. It will still do a great job on your workbench project (which isn't fine furniture anyway).
If you think you will do a lot of home remodeling projects in the future (installing crown molding or floors, for example), a miter saw is really useful for cuts of long lumber, especially angled cuts. It would be an upgrade over the circular saw for your workbench project in speed and accuracy. Personally, I build furniture for my woodworking and don't do any home remodeling, so I haven't had a need for a miter saw and don't plan to get one. If you ever plan to get a table saw, it can do everything a miter saw can do and with greater accuracy, so you might not need both. But if you have the need, this would be a good time to get a miter saw which would make your workbench project far easier and faster than the circular saw. Hitachi makes a good, cheap and reasonably accurate miter saw for around $100, sometimes less on sale. Good luck!
Edit: I looked at the workbench plans you linked in a later post. Since you will be cutting down a large plywood sheet for the table top, the best tool choice is going to be a circular saw. Or a miter saw/table saw for the frame and a circular saw for the top, if you have the budget.
doublearon98
Hamton, Arkansas
Coming from a family of wood workers, take this how you will.
Start with a GOOD circular saw, new or used. Dont get the cheap **** ones that are $30-40 new because you will not save anything in the long run. My dad has a corded dewalt that he uses to make a living with and loves it, I recently got the cordless version and we both like it. Corded version runs around $90 last I looked. You can do a whole lot with a circular saw, like cut boards or plywood.
As PugetDude said, build work bench and get a miter saw for finish cuts across the grain.
DO NOT cross cut with a table saw until you are comfortable using one, jig or not. Depending on what you wish to do, table saw would be my next purchase after the miter.
Sawzall is nice to have. You can get a cheap one from harbor freight, and upgrade later if you start using it more.
Jigsaws are more of a specialty tool and you'd probably end up rarely using it.
Never underestimate the versatility of a hand saw and hand plane.
bczygan
Get this. I use it. $30
https://www.ebay.com/itm/RYOBI-CSB124-12-AMP-7-1-4-INCH-CORDED-110V-CIRCULAR-SAW/123535938670?hash=item1cc350d46e:g:3PIAAOSwGmZcDYnz
Put a good 40 tooth Diablo blade on it. Cuts like butter. Even 24 tooth carbide will do. Or 2 60 tooth for $20.
https://www.homedepot.com/b/Tools-Power-Tool-Accessories-Saw-Blades/Diablo/N-5yc1vZc2jyZge
Get a $22.99 50" HF clamp and cut (or the 24")
https://www.harborfreight.com/4-in-1-aluminum-rafter-angle-square-63140.html
$2.99 aluminum speed square
$3.99 Carpenters square
https://www.harborfreight.com/8-In-x-12-In-Carpenters-Square-69363.html
And a $9.99 builders square.
https://www.harborfreight.com/16-In-x-24-In-Steel-Square-69099.html
or $15.99 drywall square
Bill
woody 73
The Great State Up North
Op had you listed your home town location I could have looked at your local CL and put together a nice woodworking shop for you.
Second is your budget, how much money do you want to spend?
Third what does your power source look like ? Are we talking about 120V, 220V. single phase, three phase power ?
Fourth, what do want to build ? bird houses or full blown shop cabinets?
Lots of varibles do you have any habitat places in your town, they sometimes have good deals on used power tools.
https://www.habitat.org/restores
speed bump
Butte Montana
My circular saw is almost always the first saw I pull out of the cabinet. I love the table saw as a tool but the only task I break down and go to my parents to use one for is ripping clean edges
PugetDude
Superstition Mountains, AZ
Ok, someone had to start this..
If you're right handed, get a worm drive Skil, B&D, or Makitay Hypoid circular saw. They all have the blade on the left where you can actually see exactly where it's cutting, instead of having to lean over a sidewinder to try to see the blade guide on the other side of the blade. The handle is on the end, where it's a straight push through the work being cut- a natural extension of your arm. Sidewinders have the handle on top, you have work in a contorted position, and can't reach as far. For most users, that's the difference between being able to crosscut a 4' sheet from one side and having to re-position to finish the cut.
There is a reason most pros use a worm drive. Start off with one and you'll never want to use a sidewinder.
MarvinBerry
Enchantment under the sea - NJ
If I could only have one saw it'd be a sawzall no question.
Once you get comfortable it's arguably the most versatile power saw. Can cut notches, detail work and with a couple clamps & improvised fence? Even rip full 8' sheets.
Sawzall & circular get the most use. Miter saw only comes out for trim work. Jigsaw appears for detail work & rounded cuts.
Possibly one day I'll get a table saw but it's going to be a full size industrial style, not a table top toy.
