Snowblower throttle lever help.
bagged89s10
CT
Hi I recently picked this snowblower up. I think the previous own let it sit in snow and/or with salt all over it an a lot of it was rusted. I took most of the rusted pieces off and soaked them in evaporust and painted them. The only issue I have is the throttle control lever seems to keep getting loosened when I slide it to fast, it springs back towards slow. Will replacing just the spring washer and nut holding down the lever onto the throttle control bracket help? I see part 951-11311 on the parts diagram but don’t see the lever that’s bolts to the top of it. Thanks for any help.
[ame]https://youtu.be/Cw669NzQscA[/ame]
engineer2
Chicago burbs
My HF Predator engine has a spring-loaded washer and nut to keep the throttle lever in place. The nut was surprisingly tight. I got a manual choke cable and converted it so the throttle control is up near the key switch. Much more user-friendly.
laser3kw
northen IL
here is a picture off a similar engine. you can see the lock nut and the spring washer under it. that provides the drag for the throttle arm.
- this is not the same engine as the OP-
bagged89s10
CT
Thanks all for the help. I just tightened it more and I think it is fine now. I think I was just afraid to over tighten and strip it at first.
I also stopped by my father’s place and he has a smaller version of my snowblower and snapped a picture of the lever as well.
The paint oven is an electric smoker I bought at tractor supply. I got it for under $80 on sale. It’s one of the best investments I’ve made for the garage. I paint a lot of old tools and bench vises and this thing helps cure that paint much quicker. And now I can also paint in the winter.
