GrantOpus
I’m trying to get power out to my new shop over the holiday and of course I have some questions.
It will be a 130ft Run.
I have 200A service to the house (main breaker is outside at the meter).
I am planning on adding a 100A breaker in the outside panel that will feed the shop
I am wanting 100A panel in the new shop.
This is the panel I was planning on buying, but I need to surface mount it and am not sure if this one will work.
Homeline 100 Amp 24-Space 48-Circuit Indoor Main Breaker Plug-On Neutral Load Center with Cover - Value Pack
https://www.homedepot.com/p/204836362
Ground bar for panel:
23 Terminal Ground Bar Kit
https://www.homedepot.com/p/100129430
I am planning on 2AWG THHN copper for the two hots and common. (Red, black, white)
https://www.wireandcableyourway.com/2-AWG-THHN-Building-Wire.html
I am planning on 4AWG THHN (green) for the ground
https://www.wireandcableyourway.com/4-AWG-THHN-Building-Wire.html
Wire from outside panel on house to the shop will be in 2” conduit.
I know I need a couple of ground rods at the new shop, (will these work?)
1/2 in. x 8 ft. Copper Ground Rod
https://www.homedepot.com/p/202195737
I also need a disconnect on the outside of the shop (I think) or is the 100A breaker on the outside of the house at meter panel sufficient?
Anything that I am overlooking?
The shop is a metal carport style building (not sure if that matters).
I have attached an outside and inside pic.
