Raisedonadeere
I want to install lights in 3 small clothing closets under easy attic access. Just wondering if I can feed the 14/2 nm-b through a small hole in ceiling from a light fixture suitable for making the connection — fixture covers hole. I have seen that done with fluorescent fixtures but have wondered if meets codes.
Just trying to do this the quickest way and hope to avoid installing ceiling junction boxes. Is there a pull chain type LED fixture that can do this?
Perhaps there are 2’ LED tube fixtures available that will accomplish this. If not I may just bite the bullet and install ceiling canisters that you install from below through a 5” hole and snap in place. Than I would need to run a wire down a wall for a wall switch. That approach involves a lot of messing around in 20” of insulation whereas:
If I could feed wire from below up through the insulation it is an easy pull to a existing wall mounted junction box in the attic. Wouldn’t need knee pads and face mask for that.
All ideas appreciated including things I need to avoid. Also I am thinking low budget but not trashy.
