I took a light fixture off to look around for obstructions prior to running speaker wire through the ceiling, and was horrified to find what you see in the picture - no cover on the junction box. The white romex coming into the box (properly) is from the builders - this light fixture was put in during construction. Prior owners added the grey romex, went through about 3-4 joists, and added another junction box for an add-on light fixture. I just can't believe people would be this stupid and dangerous - there is an unused knockout! What possible justification was there to do it this way?
The fix seems simple enough - go get a fitting and cover and run the grey romex through the available knockout. I'm just frustrated to see this - we have been in the home for 11 months, and this is pretty f'n dangerous.
I'm mostly venting, but also looking for input on the way they ran the grey romex through the joist - is that ok, or should there be some kind of fitting to prevent the sharp edges of the wood from potentially damaging the wire? I can bet the (new) romex is not affixed per code, but I'm not too concerned about that given the short run length.
Scary stuff. It does have me thinking to spend a saturday pulling each of the lights down to really have a good look, but I'm trying to temper myself with some logic, and maybe only look at areas where they likely tapped into for new light fixtures that were not part of the original build.
