Movin/on
I've got a IR Rand 4000 5HP compressor setup that's been running great for 15 years I leave it on full time and use it daily. About 2 weeks ago woke up about 2 AM from noise coming from my shop about 125 ft. away and it sounded like someone with a hit and miss engine in my shop. Ran up and found the compressor running at almost full 175 psi but the control valve hadn't tripped.
The noise was the blow off safety valve opening with a pop and reducing the pressure but the compressor still ran. Flipped the breaker and went to bed. Next day it did the same but I hit the little plastic button on the control valve switch and the compressor stopped. Sprayed some silicone spray on the switch and it worked ok for a week. Then it started over pressuring again but did stop after about 15 seconds. It does have a pressure relief feature on my control valve. The control valve is only 12 years old and cost around $100 so it should be good quality
Now 3 questions: could the pop off switch be weak and open before 175 PSI?
Could the control valve have gone out of adjustment? 90 on 175 off.
What is a good control valve that will last for 5HP?
I am switching my setup to a Lincoln/Quincy similar to the QR25 size and may run it in tandem with the IR. If the pressure drops below 80 the IR will kick in and shutoff at 160.
I will have 2 pressure control valves. Otherwise the Lincoln will be the primary.
Movin/on
Movin/on
