Show your new tool arrivals
slodat
Central-ish, WA
A few new friends arrived today.
Stanley 9-1/2 block
Stanley 60-1/2 low angle block
Stanley No 4
Fulton 3711 (No 5)
Fulton 3708 (No 7 corrugated)
All were gone through by “tablesawtom”. Soles and sides ground to 0.0015”. Bought them as a set from the guy that bought them from Tom and never used them.
protegeV
DFW
Pretty sure that’s the NEIKO set. Available on Amazon for $30. - $35. Dollars. I have the same set. Good deal for the money. Used it quite a few times without issue.
WHen I was shopping, the neiko set was around $60, right now it's $55 on amazon. The one I bought basically looks identical but the only markings are cr-v and the size. Doesn't have any mfr name. I lumped these in with a few other ebay orders with a 15% coupon so they were about $30.
16again
Boynton Beach, FL.
I stand corrected, price is $55.00 on Amazon for the NEIKO set.
Rogers954
Clearfield, UT
Had to swing by autozone to return a hand vac pump rental, saw these at the counter and after seeing the popularity on here for them i couldn’t help myself, guy handed me $57 for the rental and i handed him back $22. I like them smooth and the back drag....What back drag?? [emoji23] IMG_5712.jpg
d.mcfarland
Western PA
About $9. Can't see how they could be any better/worse than Vise-Grip's model as they are basically the same.
Craftfab
Garage
Have been using these and the model with the pads and been very pleased. Half the cost of vice grips. Made in Taiwan and lifetime warranty where I can just walk in a HF and swap out a broken for new if it happens.
Alpine4x4
Central, WA
Went in to order the ratchet and he had it on promo! Got the wobbles on promo as well. He knows how to keep taking my money:lol_hitti
ChrisLS8
I've been using those, the 6" and 18" day in and out for the last 4-5 months hundreds of times daily. They are a good buy for sure
dodge610
North Canton Ohio
d60535d5b1c65b0a6f4ce74f5d53ba87.jpg54e425c0f467b26f262f7587bb5c673e.jpgSocket organizers in 1/4,3/8,1/2 inch drive OEM tools off amazon 6 piece set.
Yarpo
Minnesota
Nice! 20 for the 6 piece set is a good price. Metric are black or gray right? I was ganna buy the OEM ones too, but want a green for my metric **** :(
shanny19
PNW
So far, I’ve run into sockets from Carlyle, Koken, Proto, & SK whose through-holes are smaller than the corresponding peg on those things. This is NOT a complaint directed at the socket manufacturers, but at the idiot engineer who bought one set of Snap On or Kobalt or whatever and designed a product around it.
dodge610
North Canton Ohio
Good to know thanks I have mostly craftsman,sk,and duralast. Hoping those fit we will see.
bsaint
Manchester, CT
First time I needed one for a job. Got a single one in a pinch I'll be looking for the whole wright set online. 332d335a506970fdcdc69572d87d11ac.jpg
Sent from my BBB100-1 using Tapatalk
isuhunter
Real deals sale and a new headlight
MWEric
Wyoming, MN
I usually drill the socket out. I even ordered a Snap on 6mm to fill the tray. It showed up with no hole at all. Took a 3flute carbide drill but I got through it.
dede2897234
Northern, Ohio
5651a2989a982486e34b5f7fe4794dd9.jpgd5e2789c3edba0af426a4d6b20e6e302.jpg110b899faca6e494bf24203c0f99978b.jpgA couple more parts organizer and some consumable gloves for working in the garage.
Hi dodge610,
I have experience with the Grease Monkey and Firm Grip gloves with cleaning chemical use. Here is a small review:
- Grease Monkey: I work in I.T. and refurbish small Zebra label printers for the pharmaceutical industry. I clean the outside with either Goo Gone, Zep Write Away (as a final step to remove remaining adhesives or ink), or Zep Formula 50 (after scraping adhesives or other undesirable material). These chemicals go right thru the nitrile palm and right to the finger tips.
- Firm Grip Nitrile Coated: These gloves are much better than the Grease Monkey. However, they only last half to one day of use in chemicals before needing another pair. The chemicals don't permeate thru the nitrile coating.
David
dodge610
North Canton Ohio
Hi dodge610,
David
Good to hear I deliver fuel oil and gasoline in bulk that is what i use them for usually get a week out of a pair.
hangfirew8
Central Maryland
Late Christmas present to myself, ordered Christmas Day received 28th from Amazon. Channellock oil filter/PVC pipe pliers set OF-2.
rmsg0040
Toronto
Jaw capacity
209 - 1.75-3"
212 - 2.5-3.75"
215 - 2.5-4.5"
15" for me would have been more better in terms of reach, on my mom's equinox accessing the oil from the bottom I wish I had more reach to grab the oil filter as the exhaust is right there, with the 12" my hands are right at the bottom of the pliers and I sometimes brush the exhaust if not careful
NUTTSGT
Northern Central Ohio
While doing an upgrade to the bench grinders, I spotted Menard's 11% sale was back on. I checked out total $$ of rebates on hand and decided to replace the small Skil bench grinder.
8" coarse wire wheel came from HD.
Bldmovs
Replaced my 20 year old jack. I’m in love!
