signcrafter
- Joined
- May 9, 2012
- Messages
- 12,672
I bought an led wall mount security light from menards. This one, https://www.menards.com/main/lighti...50-c-7544.htm?tid=3659883491712305513&ipos=11.
I installed it today and went to flip the breaker on and it just flickers or flashes. I let it go for a minute and then turned it off so the neighbors wouldn't get upset since it was pretty bright and anoying. I tied into another circuit that was the attic lights. Pretty sure that is all that is on that circuit but not sure. Figured since this light takes so little electricity I could tie into it without any issues. What am I missing here? Never ran into this before.
Tomorrow I'm going to try a led bulb in one of the attic lights and see if that flickers also. It's a dusk till dawn light if that matters. It was dark when I turned it on. The temp was almost 50 when I turned it on so don't think the cold is an issue. Says it's good to negative 15 or something. I'll double check my connections but pretty sure they good. Seemed pretty much like a steady constant strobe light, not random flickers but more of a consistantly flashing.
Any advice? I can take it down and try it somewhere else I guess but that would be more work if it's not needed since it's probably 18 feet high.
