Plasma Cutter and Brake Cleaner
NWill
Columbus, Ohio
I know brake cleaner and welding is a big no no. But...
Basically, I clearly wasn't thinking and I sprayed a few parts off right above the water table on my CNC plasma . ****. I realized this when I went to cut another piece about an hour later and set the water table on fire.
Is plasma cutting and brake cleaner basically the same as welding and brake cleaner?
Does it matter if it's mixed in with ~70 gallons of water and not a vapor?
Can I just light the water on fire and let it burn off?
Stupid mistake.
WWGJD?
Thanks for any advice!
Old Man Roger
Palm Coast Florida
Total guess here, but if the brake clean is floating on top of the water, can't you just lay a towel over it to absorb the brake clean? Surprised it hasn't just evaporated.
N
NWill
Columbus, Ohio
I too was surprised when the water lit on fire! D'oh
I wouldn't think it's a huge deal but I don't want to guess with poisonous gas.
N
NWill
Columbus, Ohio
Its the heat that makes brake cleaner dangerous. Is it chlorinated brake cleaner?
Stupid mistake number 2... I didn't even look. I just assumed it was since all mine is. This was a can from work.
"Less then 45% VOC and NO Chlorinated Solvents"
No wonder it didn't work very well.
Woo! Guess I am good to go then?
rlitman
Long Island
... I went to cut another piece about an hour later and set the water table on fire.
Is plasma cutting and brake cleaner basically the same as welding and brake cleaner?...
Yes, but this is specifically with regards to CHLORINATED brake cleaner. Since the brake cleaner you used was flammable, we know it was not chlorinated.
It is the heat, in combination with UV. Chlorinated brake cleaner is non-flammable. Non-chlorinated brake cleaner cannot produce phosgene.
HaroRider
New York
Whst he said. Besides a little fire I think you will be ok.
You dont want to make mustard gas in your work area..lol
I didnt know chlorinated brake clean wouldnt catch fire.
I keep all brake clean away from heat, keeps the guess work out of things.
N
NWill
Columbus, Ohio
Didn't know that! Thanks everyone.
VocaTexas
I clean oil and grease off parts using ether. It evaporates pretty quickly and doesn't leave a residue. Plus, you don't have to worry about phosgene.
LXCam
Do it again, do it again. And take a video this time please :p
