So I fully understand why they make left and right hand twist on drill bits. And I get why most Mechanic’s Length Cobalt Bits are left hand twist since normally if you’re drilling and need that short bit it’s for car work and you’re dealing with a stuck bolt. So if you gotta drill it out anyway you might as well maybe get lucky early in the process.
I already have a set of left hand cobalt drill bits from the Irwin Extractor Kit (3101010). I’m not sure if they are considered jobber or mechanic’s length.
Question is there any reason to get a right hand twist cobalt drill bit set? I honestly can’t think of a reason since it’s not like the metal cares and a hole is a hole at the end of the day. All I could think is if the drill ***** in reverse for some reason relative to forward, but drilling into metal is a slow low power process so who cares. Less is more and all. Not ripping giant holes here.
Thanks!
Thanks!
