Indoor car cover recommendations?
djb25
North Central PA
I’m not sure if this is the right forum, but I’m not sure where else to ask this question.
Anyway... I need an indoor cover for my old Porsche.
I currently have a cheap “budge” single layer cover, but it’s in rough shape and doesn’t provide much protection from dust and dings.
The car lives in a garage that I also work in, and I’m trying to find something decent that can provide some protection during the winter (when I can’t pull the car outside).
For example, I’m about to start building a hydraulic shop press, which means cutting, grinding, etc. I’m obviously going to be careful around the car, but I’d like some increased protection. I’d also rather not buy an overly expensive cover. There are some fancy $400 Porsche-specific covers out there, but that’s not what I’m interested in. I want something robust, not necessarily pretty.
Also, the garage is insulated and heated.
Anyone have any thoughts or suggestions? There must be people on here that do garage stuff while they have a car in the garage...
mattinhg
Cincinnati
I have 3 ‘Ford Escorts’ jammed into a 2 car garage.
I use 2-3 large collapsed stacked & taped boxes covered in monitor shipping sleeves, standing on end under the car cover to protect the sides of the car. Then a layer of the blue HF packing blankets, then a layer of thick plastic painter’s sheeting. Parted & chopped a ‘Ford ******’ this way, worked great.
mikegt4
sw ohio
Since the OP is in PA I would suggest that he stop by an "Ollie's Bargain Outlet" if you have one nearby. Sometimes they have good car covers for cheap. A few years ago I found a top tier Covercraft for $30, the CC web site listed it for over $200 retail.
Covercraft also has a overstock/outlet page where you might find something at a reduced price.
https://www.covercraftoutlet.com/
MikeinNorthWales
SE Pennsylvania
Covercraft is the way to go. They have several different fabrics to choose from, based on your needs. The one mentioned earlier, Dustop, is probably what you want. They made a custom cover for me for our 1929 American LaFrance fire truck for just over $500. They probably have a patern for your Porsche, so it should be much cheaper.
You may want to consider separating the space with the car from the work space as well. Can you hang something, or build a temporary wall that would keep the dust away from the car and not burst into flames if you send grinding sparks against it? The more dust you keep away from the cover, the better your chances of not dragging said grinding dust across the car as you remove the now dirty cover.
chrismenke
Sam's Clam Disco, CA
The quotes make it seem like you're dismembering hookers and storing them in the garage.
D
djb25
North Central PA
Ollie’s is a good idea. There is one near here.
The covercraft outlet looks like it might be the ticket, though. Thanks for the link!
Stuart in MN
Minneapolis
I'd recommend temporarily tossing a welding blanket over the top of the car cover if there's any chance of sparks when you're doing this work. You can get a cheap one at Harbor Freight.
tff
Greer, SC
I have a Dustop on my CTS-V wagon. Good protection, reasonable price.
What is the weight of the fabric on the Dustop? I too am looking for a cover (for a Porsche) but don't want anything bulky or heavy (for indoor use).
Also, how tight is the fit... don't want it too tight as I think it'd be easier to take off and on. Thanks.
Steve_P
I have a covercraft as well. As said, they make the covers for California Car Cover - compare the material choices; they're not coincidentally the same
Jeepster04
I've had a covercraft evolution for awhile and it seems to be a good cover. Since owning the vehicle its not been rained on so idk how the cover performs in such conditions, but it gets good ratings in everything. Cat has been sleeping on it for years and there is no damage to the vehicle.
Purchased the cheapest outdoor covercraft cover for another vehicle and it was NOT water proof at all. Left the vehicle outside overnight and it rained. It was as if the cover wasn't on the vehicle at all. Emailed covercraft stating that the cover was not water proof at all and they said they have discovered the cover should breath so it doesnt trap water under the cover..... How about it never gets wet to begin with so there is no trapped water under the cover... IDK...
Killer95Stang
How about a Cover King custom fit silver guard through Costco. $149.00 ordered through Costco or $212 for the same cover directly from coverking.com
Colin Len
Long Beach CA
Has anyone here bought from them? They have a regularly $200+ cover for $80 for one of my cars and it seems like a no brainer or possibly too good to be true.
tinmanwpk
Jacksonville
Using the term "Heavy" can be subjective. I like it because it is a little heavy and can absorb some little rubs and pokes, so to speak. It is a protective cover as well as a high quality dust cover.
It also is a custom fit, not a loose sloppy fit. It has elastic around the front and rear to keep it from flapping and it is a neat and tidy look/fit. That being said, it is easy on/off, but it has a front and rear so it is not a universal fit. More than once I have had to "reverse" it after I started to put it on because I didn't pay attention to whether I had the proper end I was starting with for installation.
Falcon67
Merkel, TX
I've never had an issue - indoors - with the Budge covers, but correct - they do not have a lot of padding. I'm cheap, if it was a finish issue I'd throw cheap blankets over the car and then the cover.
I will say I just lost a Budge cover on the Mustang. It's outside and two days of 35~45 MPH wind pretty much shredded the thing. Not unexpected.
racerex
NY
Back when I stored my Camaro for the winter in my sister in-laws garage, I used a my Covercraft flannel custom car cover and I also bagged the car (can remember the make of the bag) with desiccant packets in the car and under the car.....also a tray of mothballs under the car.
mattinhg
Cincinnati
...Sigh... Just a regular average guy; maybe, just maybe, lucky enough build a small one man business is this grand experiment we call America.
Everyone has chopped up an ****** or two in their time.
Am I right fellas??
Klammer
Wisconsin
I've got a couple cars I store for the winter in a dusty environment. One has a fitted covercraft cover, the other has a factory cover that is very nice. I use those and put a $20 Walmart cover over each to keep the "good" covers from getting too dusty.
Spencer Was Here
Western Michigan
I was watching a YouTube video of someone making a jib crane for a pickup truck and in the background of his shop he had a car inside an inflated plastic bubble.
If you intend to store the car for a while that type of protection may work for you. I don't know the details or brand etc., but I bet it wouldn't be too hard to find on Google.
LS6 Tommy
Northern NJ
http://carcapsule.com/
I've thought about it, but things are kind of tight in my garage and I'd probably end up puncturing it...
Tommy
67carl
California
Maybe I'll catch flack for this but I have a few old King size microfiber sheets we were going to throw out. I use a California dust mop on the car then cover with the sheets. Works well. Free.
CJDave
Fairfield, Ohio
California Car Cover Company used to have a chart on there website that took into consideration inside/outside and several other factors to recommend the cover that suited your intended use. I have one and love it. CJDave.
LS6 Tommy
Northern NJ
Buddy of mine had a pristine 2000 Mustang Cobra R in one... was kinda cool, but what a hassle it was to take the car in and out of.
I've only seen one car actually removed from the bubble, but it didn't seem to big of a deal to me. They unplugged the blower, unzipped the bubble, carefully lifted it over the car off to the passenger side and drove the car out of ht garage.
Tommy
