signcrafter
- Joined
- May 9, 2012
- Messages
- 12,680
Need to run an outlet for my welder. Welder plate says 47.4 amps at 230 volts. At my last house I just ran some 6/2 with ground from the panel to an outlet a couple feet away. This house I will need to run conduit with some thhn in it do to locations. Run will be roughly 30 ft from the panel. Right now the welder has a nema 6-50 plug on it.
I'm guessing I need to use 6 gauge thhn in the conduit? Do I need three 6 gauge wires or can I run 2 6 gauge and a smaller one for the ground? Or do I even need a ground with the conduit?
Second, what size conduit do I need? I have a bunch of 3/4" stuff but not sure that will be big enough? If I'm reading the chart right I can run 4 number 6 wires in 3/4" conduit so I should be good but just don't want it to be too tight.
Thanks
Thanks
