Question on extension ladders ....
cvcman
Syracuse NY
I need a 28ft extension ladder for my pole barn...I want an aluminum one for weight reasons...Ace Hardware has a TYPE 3 for 169.00
I wont be using it that much and I weigh about 150 pounds...
I need it to change bulbs, clean gutters etc so probably wont use it more than once a year...
Is this a safe enough ladder being TYPE 3 ??
signcrafter
Personally I wouldn't climb 28' on a ladder type 3 ladder. Mine is a fiberglass 1a and fully extended it can still have flex in it. I won't even go on those flimsy 6' aluminum step ladders. Guess it all depends on how much you value your life.
C
cvcman
Syracuse NY
Well it IS a 28 ft ladder BUT I’m not going up 28ft I’m going up about 16 ft but I borrowed my neighbors 28 ft aluminum and liked the fact that because I didn’t have it extended that far it didn’t flex much
rlitman
Long Island
I don't like springy ladders either. Also, a 28' ladder can only reach a 21' roof line:
https://us.wernerco.com/support/how-to-choose-a-ladder/ladder-height
As for going up 16', yeah, that's reasonable. FYI, a magnesium ladder is even lighter, though springier. Still, I'd sooner choose a magnesium type II over an aluminum type III.
Lettusbee
A fiberglass 28 footer is a heavy handful for one guy inside a pole barn.
I think your plan is solid. My lights in my pole barn are at 14', and I use my 24 ft FG Ladder for that work.
Even that's a chore to move around inside the shop without hitting innocent tools.
jacric2005
Lane County, Oregon
My brother and I split the cost of about a 24'-er fiberglass extension ladder. I was concerned about (1) aluminum hitting electric wires and (2) wanted one that would support a person with a packet of shingles (my brother is 200 pounds). We keep it inside in his shop. I'm a pretty strong woman, but I cannot carry the fiberglass ladder by myself. Once in place it is super safe and stable. But I'm thinking of getting a good aluminum ladder, not for the real tall stuff (I have a pole barn, too).
Kaizen
New England
Yes it will be fine. Just don’t have a big guy climbing it fully extended with a bundle of shingles.
I have both aluminum and fiberglass. I will grab the aluminum one for basic stuff like changing light bulbs or other ten minute projects. The fiberglass Werner 24 foot is a bear to handle but with a stabilizer I can work at height safely and without a lot of thought about the ladder.
Don’t get round rungs. They hurt quickly.
tarmy
Nor Cal
I have both aluminum and fiberglass...and I hate my fiberglass 32 footer...too heavy.
But, If I am going to be over 10’ Off the ground I always grab it...because if you have ever fallen off a ladder from above 10’ And survived...you will always buy the best, most stable and safest tool for the job. I only own 1A rated, 300lbs. Ladders...even the short ones.
Do yourself a favor, your life is on the line. Get a good ladder...
JimH74
South Central Texas
I think I have the same that Beamrider linked to. It's a Werner 28ft, 1A, D rung extension ladder. I could have gotten fiberglass at the time, but the paint store I bought it at, said that if I dropped fiberglass in the winter, it could shatter/splinter. I lived in the northern US at that time. I'm a big guy, and I've always felt very safe on this ladder. All my other ladders are 1A also. I think this is another example of buy once, buy safe, and cry once.
B_Bimmer
Eastern Iowa
After growing up on a 40' wooden extension ladder that weighed 300 pounds and had about two foot of swing fully extended, that wouldn't bother me at all.
Wamsutta
Amarillo, Texas
From my experience, the all aluminum extension ladders wobble all over the place --- and even more so the further they get extended. However, you weighing in at only 150 pounds, might not experience that.
C
cvcman
Syracuse NY
Well I bought the class 1.....it was only 60.00 more and weighs 12 pounds more than the 3
Again I’ll only be going like 16 ft with it
Yankee
Midwest
You'll be fine. I have a aluminum 32ft that I've had for 20 years.
Main reasons to go fiberglass is..
1) weight rating- If your 150lbs, your good. 250lbs is another story
2) conductive/non-conductive- depending on usage near power lines, etc would be a reason to need fiberglass.
Using it how you mention, the aluminum is just fine.
rlitman
Long Island
Well probably too late, but for inside your barn needing a 16 foot ladder, personally I'd have gone with a Little Giant A frame combination type ladder. Extensions are fine for walls, but not too useful if you need to get to the ceiling in the center of a room.
https://www.littlegiantladder.com/
I have a few Little Giant ladders. A fiberglass 5 rung (model 22), and aluminum 4 rung (model 17), 5 rung and 6 rung (model 26). Though everyone I know is always borrowing them, so at the moment, I have none ...
Anyway, the 5 rung versions make an incredibly steady 9' A frame ladder. They're great in this configuration. They're also great when painting over stairs. But as a straight ladder, they're very springy, and the narrow rungs are harder on your feet than a regular extension ladder with D rungs.
Also, for the same length, they're VERY heavy. Yes, you get more configurations, but if you don't need the A frame, then you're going to regret lugging around such a heavy ladder.
Aaron_W
Agree that they are inferior to an extension or straight ladder for that use. Their ability to be used as a straight ladder is secondary. For outdoor work on a house I would go with an extension ladder as that is what they do well.
I mention the little giant it because of the OPs plans to use it indoors. An A frame has far more utility than a straight ladder or extension inside of a structure.
The weight is not really a significant factor, a Little Giant type ladder is nearly identical in weight to a similar sized and weight rated extension ladder and is much more compact for carrying and storage.
There absolutely are places where an extension ladder is preferred so I have both. I have a "26" foot Little Giant which makes an 11 foot A frame or 23 foot straight ladder and a 28 foot extension ladder. 75%+ of my ladder work gets done with the Little Giant. I really only got the extension ladder to clean the gutters on the back of the house and for repainting the house.
