Craftsman Atlas 6x18 lathe?
Mr. Wonderful
I came upon an older craftsman lathe for sale and wanted to see what you guys thought. It looks very clean and comes with a good amount of tooling, a three and four jaw chuck, face plate, what looks like all of the original gears and tooling fixtures.
My question is the seller wants $500 OBO. I do not see if the motor is in the picture. What is a fair price with and without the motor. I am willing to do the treadmill motor swap if there is no motor. This would be my first machining tool. I know it is a small machine, I dont think I need anything bigger as I have been getting by with none so far:thumbup:
Maui
Upstate NY
That lathe was made by Atlas for Sears and is usually referred to as an Atlas 618. This one doesn't come with a quick change gear box, but the change gears do look like they are there with the accessories, which is good. From the first photo it looks like the handle for the cross-feed screw is broken. This can happen any number of ways. More often than not it occurs when the lathe is dropped. Take a close look and make sure nothing is bent. Also check for slop in the cross-slide and apron. Run the carriage the full length of the bed to see if it binds anywhere. They tend to move smoothly and have more slop close to the chuck where they are most frequently used, but further away toward the tail stock end it might be a little tighter. Some amount of wear is expected; excessive amounts are not. Chuck up a piece of rod and see if it turns relatively true. With the motor in the off position (and you said there isn't a motor anyway) lightly lift up on the rod and see if you feel any movement from the chuck and spindle. This could indicate wear in the bushings. Lift the covers and look at the gear teeth. Are any gears broken/missing? Replacement gears can cost $10 - $40 each on ebay if you need to replace any of them. I don't see the jack shaft assembly with it, but those are often missing. The $500 price tag looks like it is in the neighborhood for what it is if it came with the jackshaft assembly. And that assumes you don't see any red flags. I'd offer him $400 and see what he says if you really want it.
This is a good lathe to learn on, but you will probably outgrow it before too long. If you can find a 10" Logan lathe, that would be money well spent. They are well designed, have tapered roller bearings instead of bushings in the headstock, often can be found with a LOT of accessories, and are easy to break down and transport. I just picked up one myself that was for sale locally. It completely fit in the trunk of my Camry, was fully tooled, and I bought it for $300.
Maui
Mr. Wonderful
Maui,
Thanks I did not notice that brokent handle! I notice on here most people are encouraged to go with bigger lathes than this. I am still unsure what I will do. I have not heard from the seller yet. Im now thinking maybe more like $300. The last few times I have wished I had a metal lathe they were smaller parts and ususally brass.
Maui
Upstate NY
Mr. W,
You're welcome! That lathe will turn brass all day long without a problem. If that is the bulk of what you plan to do it should serve you well enough. Let us know how you make out.
bmwrd0
Beaver Fever Oregon
I have one. It is a great small lathe, good to learn on and good for smaller parts. They can go for big money because they are small and a good starting place. They also have a pretty good following. I found mine for $175, but it had no tooling and I probably spent enough on parts that I am at $500 give or take. There will be people who will talk about stumbling into one for 50-100 but those deals don't happen when you are looking if you know what I mean. Maui gave good advice for checking it, the only thing I would add is to act quickly as they go fast. Parts are available on eBay and through this guy mymachineshop.net.
Good luck, and any old motor should do if it is reversible. Or not.
Here is mine:
I have since put an original motor on, that one kept letting out the smoke.
By the way, were in the PNW are you? I am an hour south of Portland.
MShaw
York, Pa.
Just for the record the later lathes had a tapered roller front bearing and a ball bearing in the rear.
Mr. Wonderful
BMW, Thanks I am still trying to work a few things out with the seller. I am west of seattle in Kitsap county. It just seems there is never anything for sale between this and the $2000 and up machines. I see what you mean about the deals everyone else seems to get lol. This forrum is full of both the luckiest and unluckiest people I have ever come accross in my life. The seller did say the cross feed handle is broken and that there is NO motor with it. Now I am not sure what to offer.
Packard V8
Spokane, WA
Don't worry about a motor. Fractional horsepower motors are everywhere for cheap.
As to how much it's worth, it's unfortunate we're 300 miles apart, as I've got a really nice example, complete, turnkey on a custom stand you could have had for less than $500.
jack vines
Mr. Wonderful
jack vines
Do you have a picture and some details? Is it a 618?
