Let it go. If nothing else stored up there, whats the issue? Add a few screws to what you have. Mostly in tension correct?
And don't use deck screws, use structural screws.
HeadLOK screws are what you want, they are available at Home Depot.
https://www.homedepot.com/p/HeadLOK-2-7-8-in-Heavy-Duty-Flathead-Screw-FMHLGM278-INDY/204307972
You get a lot of snow up there? Maybe metal brace through drilled an bolted.
First it was done wrong, secondly it is wrong on multiple consecutive splices. Repair it as recommended to manage the weight. You should use fire rated sheetrock 5/8" type X. Always bugs me why contractor do these things, most know they are doing it incorrectly.
