Miss the Pontiacs
My buddy is going out of town and since he does a lot of favours for me, I thought I would do him a solid. My buddy is a pipeline welder. On this truck he of course has the heavy welding cables. In places the insulation is cracked or even small chunks missing.
What I would like to do while he is on vacation is repair if possible. I was thinking of wrapping with what I call using DR tape. The box says B Sealing Tape. It is 1/8th” thick and 1.5” wide. I thought I had some 1/2” or 3/4” wide but if I do I can’t find it. I’m thinking after lapping the tape it would have insulating values and hopefully waterproofed. I was then thinking of using vinyl tape and then finishing off with a shrink tube outer skin.
Is there a specific shrink tubing available or simply the normal run of the mill tubing readily available?
Would the vinyl tape actually be of any value or simply go with the DR tape and the shrink tube.
Another thing I noticed is the fine copper making up main copper cable is a little blackened even to a degree inside the core of the cable. Does this have any mesureable affect on the potential or quality of the welding being done? Or does it require more power from the welder in general? This last point just had me wondering.
Replacement of these cables I am told is like $300 per spool is what I believe he said or maybe it was $300 for 2 spools. Which is still nuts.
