How do you radius a round tube ?
The Cobbler
I am working on a project that has 2 - 1" round aluminum legs that will fold up into an aluminum channel when not in use.
my plan is to pivot the tube in the channel using a 1/4" stainless nut & bolt.
I want to radius the end of the legs so it will pivot inside the channel and rest on the top of the channel when in the opened position. I figure a radius on the end of the tube would be the best option.
I have a few ideas on putting a radius on the tubes, looking for suggestions .
I want it to look neat & tidy.
thanks
bullnerd
Jersey
All depends on what tools you have available?
Belt sander pops into my mind.
Simple version, clamp a piece of wood with a "pin" in it the distance of the radius from the belt, slide the leg over the pin and rotate.
Edit: turn the sander on first.
LXCam
If you have a stationary sander of any kind. Drill your pivot hole then screw/bolt it down to a piece of wood or whatever and then clamp that to your platen on the grinder and rotate. Every radius will end up identical.
bullnerd
Jersey
Disc sander boo- belt sander yay!
lol! Just don't like disc sanders because all the **** comes back around at you!
Same difference in the end.
matt_i
SE Michigan
Best/most finished would be radius turner in a lathe. But as others have mentioned a decent job can be done with a belt sander, just rotate the part in your hands along the long axis of the material as you also swing it thru an arc relative to the sanding face.
bugnut
Central Ohio
I was thinking with aluminum a router with a carbide bit of the correct diameter, commonly a corner rounding bit.
larry_g
oregon
In my minds eye your going to want to have a step on the end of the tube if you want it to act as a stop in the open position or a raised stop in the channel for it to open against. If you radius 90* on the end of the tube and expect the flat to stop then the pivot point will have to be just in the right position and then when closed the side of the tube will hit the channel preventing the leg from fully seating. If you can draw this out to scale so you know the point of pivot and the radius and stop point so all will work as you expect.
lg
no neat sig line
T
The Cobbler
In my minds eye y......
Thanks for all the tips & suggestions.
This project is actually supports for a portable sunning platform for a buddies boat .
I have decided to NOT radius the ends of the "legs" . they will be pinned with a Bimini style pin in the open position when in use . when the deck is removed the pins will be removed & the legs will store laying flat and pinned into the bracketry for safe keeping.
I knew there was something I was missing :lol_hitti
PugetDude
Superstition Mountains, AZ
We're going to need pictures of that completed sunning platform in use...:lol_hitti
