Tips on Pouring Small Amounts of Epoxy?
jantar
Melbourne
I have some small amounts of epoxy paint I need to mix to paint some small panels over coming weeks.
Anyone have any tips on how to get small amounts of epoxy out of 5 litre tins without getting it everywhere?
e015475
Show Low and Mesa Arizona
For getting small amounts of paint out of a can to use as touchup on my epoxy garage floor I've put a soda straw in the paint, hold my finger over the open end and extract a straw-full at a time. Throw the straw in the trash when you're done.
I've had pretty good luck getting the weight ratios correct using a digital kitchen scale that weighs in 1 gram increments.
e015475
I suppose if you needed more than a half a dozen straws full of paint you could take a couple of plastic tubes sealed into the lid of a glass jar and **** what you needed out of the paint can.
CraigStu
Blacksburg, Va
Not sure how small your small quantities are but I have used these pumps
You would need to check if the epoxy you are using mixes at the same ratio as the West System epoxy.
matt_i
SE Michigan
I have cut the bottoms off plastic 20oz soda bottles leaving a longer tab on one side. Wash and dried them. Make 2 of identical height.
Using the tab as a handle, dip one into Part A and another into Part B until you have equal amounts, then mix in a clean container. Its not as scientific as using a scale but has worked for me thus far.
ez-duzit
Marina del Rey
These are the ones I use for tiny batches of epoxy.
J
jantar
Melbourne
Thanks for the great ideas, I'II give a couple a go. Its about 50-100ml that I seem to keep mixing.
Thanks
Chris
nes999
IL
I use a mix of syringes from TSC, normal straws and Boba straws. What normally happens is I make way too much wasting a bunch of materials.
Sent from my VS988 using Tapatalk
22george
SW Ohio
I got the idea of using prescription bottles from Robert at MCP&C to mix the paint in. The idea of straws to measure sounds ideal to me.
lbhsbz
Long Beach CA
That's brilliant. I have a gallon of West Systems resin and a quart of hardener that I've been trying to figure out how to measure small amount of so I can use some of it before it goes bad.
ez-duzit
Marina del Rey
...I have a gallon of West Systems resin and a quart of hardener that I've been trying to figure out how to measure small amount of so I can use some of it before it goes bad.
Recommend you use the mini pumps or, if you need much smaller quantities, use a digital scale, such as that used by ammo hand loaders.
