Picked up a yost 8" can't find much info on it can anyone tell me more about it
Picked up this Canedy Otto 4inch Vise this evening for $50. Couldn't find much information on the company, in terms of Vises, when I looked before heading out to buy it other than that they built a lot ot drill presses and lathes. Seems a very solid Vise. I took it apart for cleaning. What do you guy recommend for general cleaning and degreasing, Simple Green? And what is your preferred grease to use when rebuilding a Vise?
Simple Green is good. SG can also remove paint, so if you are trying to preserve the paint, don't soak it.
I use Mobile 1 red grease. (synthetic) - this was just discussed at length in the vise repair thread.
Thanks to all for the information which helped my sort out my pin on the Reed 405! I’m not sure I would have even recognized the problem without you all. I’ll tell you straight up that I am bad at math. A nice fellow on another forum I frequent happened to have the same vise and sent me dimensions. With those, I made the pin on my lathe using the compound. It took a few tries to find the right angle. I basically had to put bluing on the pin and make the angle so that it touched along the length. Hand fit I guess. It rings in the hole nicely and there is no slop on the stationary jaw. I did drill and tap it for a dowl puller and will order a lift eye to fit the threads as was suggested. I am able to give it a tap with a copper hammer and it seems stuck but won’t go deeper. I can remove it with a pull from my fingers and another tap to the side of the pins head with the same hammer.
Material used is 4140 steel.
Wabo:
YOST is great old USA company and i think they still make vises here in the USA instead of having everything made in China like some vise/vice companies have done.
I purchased my Yost in about 2013 and only a couple units were made in the US. The ones from Taiwan may be really good but I went to the used market for my next. The Wilton bullet vises are expensive as all get out but still USA I think.
Rise
That is a nice find. It looks like you might have already found the Canedy Otto Co history page
http://vintagemachinery.org/mfgindex/detail.aspx?id=153
Per the info on this page Canedy & Edwards was established by William Eaton Canedy in 1889. It seems Canedy- was sold at public auction in 1949 and purchased by the Cincinnati Lathe and Tool Company. And operated as the "Canedy-Otto Division" of that firm. This division reportedly lasted until 1956.
As you pointed out it seems that Canedy Otto was better known for its lathe and drill presses but did manufacture other tools and equipment including vises.
Over the years some of the other members have also have come across these vises, here are two links to their posts
https://www.garagejournal.com/forum/showthread.php?t=160479
https://www.garagejournal.com/forum/showpost.php?p=1913071&postcount=3270
A 4" Canedy like yours just sold on eBay few days ago (see photo).
There are only few Canedy vises listed in the vise spread sheet and your 4" is not listed. If you provide some basic stats (we already know the jaw width is 4") including opening and weight KMSCOTT (aka Dr. Scott) who maintains the spreadsheet can add your vise to the list.
Here is the link to the vise repair thread that Outlaw mentioned
https://www.garagejournal.com/forum/showthread.php?t=252830
SmittyRe: Loydski29
Thanks for the tip on the post vise, I really appreciate it. The vise has 6” jaws and weighs in at 102 lbs. and is in great condition. I offered him $150 for the vise and he took it. He also Had an old Athol 624N that he took $40 for. I can’t wait to strip the five layers of paint off of the Athol, it seems to be in pretty good condition.
Sent from my iPad using The Garage Journal mobile app
Nice, I can’t recall seeing a lot of Athol pipe vises.
The 624 on the left does feel a bit more stout now that you mention it.The dynamic jaw support quite a bit different between those 2. Interesting.
Thanks Jeppen. Chris remarked about the “N” designation after the 624. What do you feel that designates?Found this page in my Athol notes with -3- different examples from different time periods.
Re: Loydski29
Smitty I’m Glad it worked out! The post vise looks like it’s in great condition! Nice score on the Athol as well!
BTW, what techniques do you use to “polish” the slide?
wire wheel? Scotchbrite discs? RO Sander?
I scored this little vise on Thu at an estate sale for $3 while visiting my mom out of town. I'm thinking it looks like a small drill press vise. ?? I can find no maker's mark or COO anywhere on it. Stamped on both arms in the same place is "Pat Apl'd For" in a circle. I'm hoping you guys can tell me who made it, where it was made and when? Oh yeah, and what it's actually used for? Thanks!
Yeah, the post vise is really clean and the Athol is a prime restoration candidate. Thanks again.Re: Loydski29
