Between the River Hills & the River Bottom
C
cliftonbros89
Missouri
Tuesday morning was froze so it was a good time to check on all the cattle, put out mineral, and put out a few batches of feed.
After taking care of the cattle I was back in the shop. I started getting all the engine and hydraulic oil back in the 4440.
But that didn’t last very long.
We attended a meeting on cattle mineral and the like. It was informative, even if it is obvious I drew on the copy of the brochure during the presentation.
After the meeting we had a few stops to make in town. But then it was back to the shop.
I had to remove the air filter and some intake hoses. Then checked the valve gaps and adjusted things since I had the valve cover off.
I can say these two pieces here were definitely worth the investment. For checking timing of the pump and for valve adjustment.
C
cliftonbros89
Missouri
Today was a different story than yesterday. Warmer temperatures. But in the early morning hours we had over another inch of rain.
I put out a couple bales of hay out at the retirement farm. As you can see it’s basically a big wet mud pit around the area where the bale feeders are right now. But there’s no a whole lot to do about it.
Dad did some running around today taking care of some stuff. But I kept on the 4440. I got everything back together. But then had to bleed the fuel system.
I had lots of options available for the injection lines.
#6 was a pain to get to and to get undone.
I had quite the set-up cluster to get to it. But it worked. I think it would’ve been impossible with my line wrenches.
It took a bit, had to prime it, then it seemed to flood itself a bit, but I finally got things lined out and got the 4440 going again.
Also experienced some issues with a battery cable. But fixed it too.
After I had things running I took it for a drive to make sure everything checked out.
It seems like everything is good to go on it. So I gave it a much needed bath.
I picked up the shop a bit and cleaned some things up and cleaned up my tools.
I’m really liking the additions to the cart. It lets me space things out a bit more and definitely allows me to carry more.
I had to quit early this evening for a Extension meeting.
Lots to do yet. But it’s going to be muddy for awhile and even more rain coming by the weekend. It’s bringing some more unseasonably warm weather too. So it sounds like it’s going to be the same stuff all over again. I’m tired of mud!
C
cliftonbros89
Missouri
There's nothing wrong with buying Hardware in bulk, minus trying to sort through all of it like the OP.
If I'm planning a decent sized project I just buy new as opposed to trying to find 8 matching bolts etc; the time saved is worth the $1.60 :thumbup:
I completely agree with just going to buy a few bolts to avoid going through the trouble to trying to dig through a bunch of other stuff to find what you need. I’ve done that plenty of times.
I’ll usually buy extra of what I need should I need it later and then keep it organized so I know I have it, know where it’s at and have easy access to it. Easy enough if I have to have someone else get it for me I can tell them exactly where it is.
My only problem is the fact that me co-workers (dad and my uncle, occasionally dad’s friend, also a few of my other uncles who’ve dropped things off or dropped in to use something) have always had a bad habit of not putting things away. Or just piling everything together. Which becomes a problem when this continues over several years. Then when something is needed it can’t be found and more is bought. Therefore, the cycle continues. It becomes a waste of time and a waste of money.
Over the last, ill say 5 years or so, I’ve spent parts of winter sorting out what has (I’m pretty certain) has amounted to roughly 30+ buckets, multiple upon multiple (and I mean multiple) cardboard boxes, coffee cans, popcorn tins, what have you full of all kinds of miscellaneous hardware. Bolts, screws, nuts, washers, staples, electrical supplies, you name it. All stuff we had, was perfectly useable. It was just that no one wanted to dig through it. Now we have enough 4” and 5” ring shank nails we shouldn’t have to buy any for 10 years, buckets full of tin roofing screws, more cotter keys than we’ll likely ever use period and that’s just the big stuff.
But someone had to do it.
XJSuperman
Central Iowa
Every family has that person, and they either tackle the problem head-on like you, or circumstances keep them from doing it. For me, I'm that family member, but I'm 700miles away. So nothing gets done unless I'm home or pushing dad to to something else where this gets in the way and he is forced to clean up. Keep after it, it all pays off. The rewards are organization, better workspace, better storage space, cleaner appearance, and of course the cost value you mentioned.
C
cliftonbros89
Missouri
Started the day with checking on things out at the retirement farm.
I went down the road and checked on the rest of the crew.
Dad was getting some things ready. He’s heading out for a tractor pull in the morning.
We had yet another meeting today.
Financial company had a meeting today on farm financing stuff, they also discussed changes in crop insurance and appraisals.
So after the meeting and a chiropractor appointment I headed back to the farm.
Dad and I put out hay this evening.
I also finally put away the parts from the parts sale.
I checked the list and added things to the inventory list.
That pretty well sums up the day. I checked over my list of replaced parts for the 4440 as well.
As you can see I have a lot of papers for the 4440. I have my filter paper, the service/inspection papers, 3 papers of parts replaced since 2014, a paper outlining some major repairs and services, and now included a copy of the invoice for the pump repair.
One thing I though I might try is a more stationary funnel option for the rear of the 4440.
Few adjustments, but I think it could work.
C
cliftonbros89
Missouri
So in the midst of moving things around in the shop and relocating stuff I grabbed the little side box from dad’s older craftsman box.
The box it came with is in the van trailer for the pulling tractors with parts and tools. This box was then moved to the other craftsman box which we just recently moved to dad’s basement. I don’t really know what I’ll use it for. It’s too big to use on top of my toolbox. But I’m not sure it’ll work on the new supply cart. But I don’t think I’d need it for anything on the live cart. So it’s just hanging out for awhile.
I’m looking for some ideas for it. It could use a cleaning. A few drawer slides also need some work too.
C
cliftonbros89
Missouri
I used to never be that person. But I couldn’t help it after awhile. It became frustrating not be able to find things. Also having tons of things just sitting around in the way.
Like you said it definitely helps with workspace and storage space. I’ve found more ways to take advantage of space to actually store more things than was there before. Which in turn can make them easier to organize and easier to find.
I often mention how I’m always cleaning up the shop. That’s in part because dad or my uncle with get something out, use it, then just sit it anywhere, before you know it a few days pass and the work bench, the welding table, and the bolt bench are all covered in ****. Parts, bolts, tools, whatever. So it’s usually up to me to pick everything up and put it back away so there’s room to work again.
C
cliftonbros89
Missouri
Today when I got down to the farm mom told me grandpa sent something for me.
A 1/2” drive double male adaptor. No brand markings. It definitely has some age on it. I’m assuming he’s had it sitting around for some time. Interesting to say the least.
C
cliftonbros89
Missouri
Well Friday did not start off well. One of the young cows out at the retirement farm died early in the morning. The one that just had the calf a few weeks ago. She laid down and moved her back down hill which caused her to stick in the mud and she exhausted herself trying to get up.
Needless to say I was pretty pissed. This was only her second calf, she was well behaved, easy to work with, showed a lot of promise. So we loaded her up and I buried her later. But catching the calf seemed to be totally impossible.
So I checked on the rest of the cattle and tried to get some more straw out for the them. Things were so muddy I ended up just turning some of them out on the main pasture just to give them a break for a couple days.
So all my plans were shot for the day. Late afternoon I went back to the retirement farm to try and catch the calf again. So with some patience and time I finally got him in the lot. With some help from the owners of the farm I got the little guy in my truck.
So I took him down the road and put him in the barn at dad’s.
So it looks like it’s up to us to raise him. I started him on a bottle. He’s a little wild but luckily he’s taking to the bottle pretty good.
So mud and cattle pretty much took the whole day up for me Friday.
C
cliftonbros89
Missouri
For Saturday we luckily didn’t get the rain that they were talking about. We just ended up with a sprinkle.
I checked all the cattle, fed some corn, fed the calf, then I went in the shop for a little while.
I got the 4440 all waxed up after I got the shields and hood all washed up. So I just have to look a few more things over, clean the windows and clean the cab out and it’ll be good to go. I’ll be glad to get started on something else.
C
cliftonbros89
Missouri
No break today. I just stayed at it.
Had a few things added to the toolbox that arrived the other day.
Fed the calf this morning.
I finished up with the 4440 and got it all cleaned up and back together.
Then dad and I decided to get a head start on tomorrow.
We loaded both trucks up with corn to haul some loads off tomorrow.
Calf is doing well. Finally some sun, warmer temps and some wind. The wind wasn’t enjoyable but it’s making a difference on drying the mud slightly so I’m take it!
C
cliftonbros89
Missouri
Well not much to report from the last few days.
I’m addition to taking care of and checking on the cattle. We hauled some corn and some beans.
Emptied a few bins too.
Also, been doing some more feeding.
I did have a little time to checkout some of those old hay tarps too.
It’s actually drying up. No rain the last few days. We’ve even had some sun, plus some warm temperatures. But chances of winter weather are nearing, not to mention some cold temperatures again too.
Dad had a doctors appointment today and is going fishing for the weekend and is leaving tomorrow. So I’ll be on my own.
Good news is the calf is doing good. However, there is another new calf I’m a little concerned about. Born to a much older cow I’m not sure she’s producing enough milk for him. So I plan to keep a close eye on him.
C
cliftonbros89
Missouri
C
cliftonbros89
Missouri
As nice as Wednesday was, Thursday was not so nice.
Luckily, it didn’t amount to much. But the day started out with what was supposed to be rain and ended up turning into freezing rain and sleet. It formed a nice layer of ice on everything. Which made the gravel and lots slick.
With the 4440 basically being wrapped up I decided to get it out of the shop.
So we backed the planter in to start looking it over. There are some bearing to replace, things to adjust.
All the back rows need new scrapers between the disk.
The awesome thing about this Kinze planter is that you can just about adjust or take anything part with just a 15/16” or 3/4” socket or wrench. It doesn’t require much.
I’m also going to go through all the meters to make sure everything is good to go. But with everything else going on it’s likely to take awhile to go through everything.
On a a side note I’m really glad I made those additions to my cart.
I really helps to move things around the shop when I’m working on stuff. I’m liking it.
C
cliftonbros89
Missouri
Well the orphaned calf is doing good. Couple bottles a day and I’m trying to give him a little bit of some sweet feed to give him a little something extra in between bottles. He’s looking healthy and staying warm inside the barn.
If you recall me saying there was another calf I was concerned about I was right to be concerned. He looked ok on Wednesday afternoon. Not 100% but he looked good. So Thursday morning I told dad I thought we should attempt to bottle feed him a little bit. He didn’t seem to be getting the proper amount of milk from the cow. So first thing Thursday we attempted to go get him. However, we pulled up on him laying in the straw almost motionless. The cooler temperatures that set in over night along with the lack of milk just about did him in.
I loaded him up in the Kubota. We put him in dad’s basement, I dried him off, wrapped some towels around him, and put a heater near him to get him warm.
I let him rest for awhile in hopes if he warmed up I could maybe feed him some from the bottle. But he never seems to recoup. I spent a majority of the day with him, trying to get him warmed up, getting some of the spots of wet or dried mud off of him, rubbing him a bit trying to keep him warm, trying to sit him up. There were several times through out the day that I tried to get some milk in him with the bottle. He was too weak to **** on it himself. I gradually tried to get some in him. But it didn’t help that he was unable to swallow it.
So like I said this went on through the day. We got him in the basement by around 7 or 7:30 that morning. Nearing 6 that evening he was worse. At that point it seemed he barely had the strength to keep his tongue in his mouth. His breathes were very labored and delayed. He didn’t even have the strength to let out a bawl anymore at that point.
So I knew at that point there wasn’t going to be anything else I could do for him. Had I taken him in the evening before I think he could’ve made it. But trusting he could make it to the next morning was a mistake. I decided at that point the best thing I could do was get on with things and end his suffering.
So not the greatest day. It’s always a pain in the *** to loose them. Especially since we just lost that young cow last week. But it’s all part of it. When there are this many and with it being this time of year it’s hard for them all to make it.
C
cliftonbros89
Missouri
So Friday morning sucked a little. The ice from Thursday had thawed a bit then froze overnight again. So everything had a slick slippery sheen to it.
I fed hay and corn to all the cattle. Strawed the barn at dad’s for the young calves and ground some corn to put in the tank to bucket feed.
I also had to do some running. Meeting with a landlord. Also, running to the New Holland/Kenzie dealer in town to get some parts for the planter.
There’s $100 worth of stuff in that small box. That’s with the current sale price too.
So dad is out of town with mom. March 1, as I believe I mentioned last year is the start of trout fishing at the state parks in Missouri. I don’t think dad has missed an opening day in about 25 years. So they’re gone for that. But may be returning a day or so early due to some incoming winter weather.
With him being gone his friend, who occasionally helps us out, thought he needed to help me feed with dad being gone. Don’t get me wrong, I appreciate help, I don’t want to sound like an ***, but sometimes I’d just rather take my time, work by myself, and do things the way I’d like them to be done.
However, with him being around things don’t work like that. It usually turns into he thinks he needs to give the orders and make decisions. Which usually aggravates me and usually ends up in things taking twice as long, which naturally aggravates me even more.
Matters were no better when he showed up yesterday morning with his son and his daughters boyfriend. His son is 15, the kid is eager to come down all the time but he thinks farming just consist of cruising around on Kubota or 7230 all day doing nothing. His daughter’s boyfriend he brought along is about 19, know it all, lost his license, doesn’t have a job, lives with them and does nothing. The combination of all these things can really irritate me. Like I said, I’m not trying to be an ***. I try to be a nice guy. But I’m sure if you follow along and have picked up on anything. I tend to like to have things done in an orderly fashion and when I want it done it needs to be done and we’re not going to mess around. There’s work to do we’re going to do it right and get it done.
Warning: at this time this post turns into a bit of a rant.
I told dad’s friend if he wanted to put out hay that was fine. I told him what type of hay I wanted fed where and how many bales to put out. I told him where I wanted him to spread some straw out. All he had to do. But it turns out he didn’t put out the hay I told him to. He put out what he thought was best, which was what was easiest to do.
I told the boys right away to grab 6 buckets of corn for me and 4 bags of mineral. They messed around on the Kubota before finally doing it. I had to get on them I was not in a mood to mess around since we had things to do.
The daughter’s boyfriend went with dad’s friend. His son came with me. While the other two were putting out hay, the son and I opened gates, fed corn and put out mineral.
The son is not a very productive worker. I try to be nice and fully explain what I want him to do, a lot of times I even show him how to do it. But it wasn’t much use. He didn’t listen when it came to feeding the corn and had a hell of time with the mineral bags. He insisted on complaining about the mud as if I haven’t been doing the same thing in the mud for the last 3 months. But I just bit my lip. He seemed more focused on being bummed out that I was the one driving the Kubota and that he had to lift 50 pound bags of mineral.
Now the crew that was putting out hay. As I mentioned didn’t put out the hay I’d told them to. The straw bales they picked to spread out were the worst 2 and soaked from sitting outside bales that they could’ve picked. Then the daughter’s boyfriend was riding along in the cab in between putting bales out he just left the cab door wide open. Open to catch any cow, feeder, fence post, whatever that could easily be hit and break off or completely shatter the door. With this crew it’s easy for something to be broken so I wasn’t taking any chance. I received an eye roll when I told him that was likely a $500 door and I’d appreciate if he kept it closed so it wasn’t damaged. That’s the type of stuff that irritates me. But I just have to remember. He’s 19, clearly full of dumb decisions, it’s all part of it.
That’s just a touch of the annoyances of the morning. Luckily, after the feeding was done they left. I try to be patient, I try to bit my tongue. But a lot of little things can add up and build up frustration. I know I should be appreciative of the assistance. It’s just that this is the guy that always wants to borrow something, usually ends up breaking something, always wants some sort of a hand out, wants to take something for nothing, wants to only do things the way he thinks they should be done, it’s just hard to handle after awhile.
Before they left while I was putting thing in the barn I saw them load up about 4 pallets in the bed of his truck. I asked what they were doing. He said, “oh I was wanting some pallets for some stuff, you don’t mind do you?”. Don’t get me wrong we have a big *** stack of pallets, you’ve probably seen them in pictures back by the grain bins. Am I going to use them? Probably not, at least not all of them that’s for sure. It’s just the principle of asking someone for something instead of just assuming you can take something that isn’t yours to begin with. It wouldn’t be a big deal if this was the first time it happened. But it’s not. He tends to think an hour of his help is worth him getting things for free all the time. Or an hour of his time is worth an hours use of one of the tractors. It doesn’t work like that. But it doesn’t help that my dad can never tell anyone no. He’s never been able to. That was always my uncle’s job. My uncle was always the jerk. Which is the position I’m going to have to fill.
Ok I know that was a lot. Sometimes you just have to get this **** off your chest. I have to deal with a lot as it is. Dealing with other people’s BS doesn’t help things out and I don’t have the time for it. So rant over. For now.
Excuse me as I may have to go slam a beer Stone Cold Steve Austin style after something like that.
lis2323
Hope the beer helped. Nothing worse than unwanted “free” help.
At least you can tell an employee to “hit the road”. And yeah, I know even that’s easier said than done these days. Glad I’m done!
Jon69RagTop
Stand up and let’em have it. My guess is it will only take one time, your dad will hear of it, and then slap you on the back and say “good job”.
1953mercury
Steamboat Springs CO
Seems there are all kinds of shortages in the world, but there never seems to be any shortage of assholes for some reason. One of the few benefits of becoming an old man is that I'm not as prone to taking **** as I used to be. Hopefully tomorrow will be a better day for you. Cheers, Mike
C
cliftonbros89
Missouri
Not much going on Saturday. Zack came out to help me out for awhile. We checked on the cows, checked on the calf in the barn, and did some work to the planter.
While he was down I decided to have him help me get some more things straightened out in the shop.
We cleaned out and reorganized the welding table and also the bolt bench I showed a few weeks ago. But now I’d like to add a few things in on the welding table to keep things organized and make more space for things. But that’ll be another day.
So not much activity.
C
cliftonbros89
Missouri
Sorry to hear about the calf, and the useless friend.
Thanks. Just got to shake it off and keep moving on.
It’s definitely about to come to that point of telling them to get out of here!
That’s a very valid point! Lots of assholes out there. My girlfriend tried to tell me that I’m too hard on people and I’m just a crumpy old man. But people don’t always remember a farm is still a business.
I’m very close to the point of really going off!
C
cliftonbros89
Missouri
So I’ve been thinking about getting a dial indicator set up to use. I’ve noticed a large amount of things in multiple service manuals that I could use one for to check wear and what not on several things on the tractors. But I really don’t know anything about dial indicators. I’ve never used one. I’m trying to find some options for one. But I’m not sure I really want to spend $250+ on a Starrett set up either.
Anyone have any suggestions for me?
XJSuperman
Central Iowa
In my family you may be in the right, but if you blow your top on a friend of the family, its gonna come back on you and probably not the full story, and then you get an ***-chewing from Dad or whoever because the friend is a crybaby when he doesn't get his way. Im right there with ya, thats for sure.
C
cliftonbros89
Missouri
First thing I did this morning was immediately went off on dad for saying anything to them about coming down to “help” me. The thing is he knows exactly how they are. But he can never tell people no which is a problem. A large problem.
The guy pulled up on Friday morning right as I’d gone in the house to wash out the calf’s bottle. I saw the whole crew get out of the truck and took a picture of them through the kitchen window. I sent it to my dad with the caption, “thank! Lets see if I can make it through the day without choking one of them!”
Sifan
Southern Illinois
No matter what they are getting ready to load up ... Whoa wait a minute, I've got those set aside for a project ... and point them to the farthest away, hardest to get to, and most broken down ... you can have your pick over there :)
Farm I used to work at, putting myself through college, preacher called up at lunch time to beg for some green beans. Farmer told him sure come pick what he wanted. Preacher claimed he didn't have time to pick them, have me do it and he would swing by and get them. I got to pick a grocery bag of green beans for him. Now I was getting paid to do it,but it still aggravated me. Just so happened as I was picking a small garter snake happened to end up in bag of green beans :)
C
cliftonbros89
Missouri
After taking the day off Sunday, which was the first day off in a few weeks, it was back it today.
Early Sunday we had a bit of snow fall. Luckily, it didn’t end up at all as was predicted. Just a dusting for the most part but it also brought wind and some colder temps. But we started with putting out hay today.
Then it was back to the planter.
Got most of it looked over this morning. But there are still some parts to get
Still some bearings to replace and some chains on the front units to replace too.
I got my list of parts together and drove to town to go get the parts for the planter. I arrived at 4:45 thinking I’d be just in town...but apparently the New Holland guys close shop at 4:30...so my plans for the evening didn’t work out to well.
BORING HOP YARD
Boring Oregon
Greetings.
A good rule of thumb on measuring tools, you want the measuring tool to have twice the accuracy of the feature that you are measuring. If your measuring a feature that calls for +/- .010 your measuring tool should be capable of measuring +/- .005. You also need to take the accuracy of the tool into count after you have the measured value.
Lets say your tool is capable of .0005 and if you measured .0105 using the example above, you could still be within an acceptable range since the tool has a known limit of accuracy of .0005, same at the bottom end if you were .0005 under low limit.
The higher priced precision tools have a greater repeat ability "in my opinion"
I have done gauge R & R studies (gage repeatability and reproducibility) to determine variation in the tool and the person measuring the feature. This is how we did in aircraft manufacturing.
Have you ever verified your measurement by measuring the same feature a few times? I bet you have when you found something out of spec that would require a fair amount of money to be spent on replacement.
In my opinion if I was in you shoes I would buy a good indicator just based on the value of the machinery that your working with.
So have you ever used plastic gage on measuring the clearance on a crankshaft?
People have been using since 1948 and it works fine when used correctly, I used it with my Dad when I was a boy. It serves a great purpose and has been around for a long time. Plastic gage would fail a gage R&R since is so subjective vs a micrometer, but both work when used correctly on the right application. Cheaper tools may work for you but may cost you in the end.
Hope this helps.
C
cliftonbros89
Missouri
Greetings.
Hope this helps.
Yes. Thanks.
I think I’m going to have to look into things a bit more to see exactly what kind I would needing most. I’ve been wanting to look into an indicator and a few micrometers for a few years now. They can just be so expensive and I wouldn’t need them that often. But I know should I start to get involved in some more intricate and precise jobs they’d be worth in. I’m just not sure exactly what I’ll need or what to go for.
C
cliftonbros89
Missouri
Another chilly start today. I started with going to the retirement farm and checking on things. Luckily, all the cattle and the calves came in the lot right away so I locked them all in the lot. I decided today would be a good day to ween calves.
After that I went down the road to check on the rest. I started with the calf in the barn.
We started giving him more milk over the weekend so we switched from the bottle to the bucket. He’s doing really well. I tried to get him to start on a little bit of sweet feed over the weekend but he just hasn’t had any interest in it yet. I’ve seen him nibble around on straw but hopefully before too long he’ll start on a little bit of feed.
Dad ended up with a meeting this morning. So while he was gone I checked on the rest of the cows and put out some corn for them.
Dad’s meeting ran longer than expected and I was waiting on him to stop and get some more of the parts for the planter. So while I waited I did a few little things around the shop.
One being sorting out a bunch of stuff and separating it into the drawers on the supply cart. So not only is it all sorted, but it all freed up about 10 drawers in the cabinet of the bolt bench that can now be used for storage of other hardware that we don’t use as often. Along with the roll pins, grease fittings, hitch pins and cotter keys I also sorted through the hose clamps. But I still have one big bag of mixed cotter keys to sort. But I’m going to have to go some place else with the overflow of them.
It took awhile but dad finally arrived with the planter parts.
Although not all of them. There were a few things that they had to order. So I have to wait on them.
So this afternoon we put the planter on hold to go take care of the calves. First we went out to the retirement farm. We rounded up the 5 calves out there. Then over to my uncles, 10 more calves there. After that we went back to one of the lots behind my uncles and rounded up another 10 calves. So 25 we weened all together this afternoon. However, there are at least half as many of that we still need to seem very soon. Unfortunately, the lot we keep calves in when we ween them can only comfortably fit a max of 25 calves. So we’re going to have to wait a bit.
So after we gave corn and hay to the weened calves it was back to the shop.
I have most everything looked over on it. I have the row units all looked over and have the back rows ready for corn.
This evening I also replaced all the worn roller chains on all the front units.
But things are starting to go back together now. It’s getting closer to being finished and ready to go.
C
cliftonbros89
Missouri
So last night I stopped by the Matco guy’s house for a few things, and this morning I knew the Snap On guy was in the area so I met up with him.
The 13mm, 15mm and brass punch are Matco. The 18mm angle wrench and long screwdriver are obviously Snap On.
In addition I had a few feeler gauges from McMaster-Carr show up too.
.040 and .060. I’ve had a few times I could’ve used a long .040 gauge and I can use the .060 on the planter.
C
cliftonbros89
Missouri
Not many pictures from today. But it started out as always. Checked the cows, fed some corn, checked on the newly weened calves and gave them some corn.
We had some stops in town to make today. Got a few more parts for the planter and picked up some more milk replacer for the calf in the barn.
We got new seed firmers and replaced the ones on the front rows of the planter. As you can see they were just about gone. If you remember I replaced the back section last winter. So aside from the we locked up the front rows so just the back rows are on the ground so it’s ready for corn. Just a few more parts to go that should be in by the end of the week and the planter will be ready to roll.
So this morning we went by the retirement farm to check on the cattle. They needed some hay. We also did something else today. We’ve been talking with the lady who lives out there. She’s the oldest sibling and in charge of things for the farm. Since he father passed away last year they decided to get rid of some of the old equipment he had. They’re taking it to a consignment sale that’s going on this weekend.
We’ve been in talks with them about their 4010 that resides beside our 3020 in the hay shed. We talked with them on price a bit. We were interested in the tractor, but not the old not so heavy duty home made loader that was on it. So they came down a bit in price. We told them we’d remove the loader and take it the consignment sale for them to sell. They agreed and said whatever the loader brought they would remove from the price of the tractor.
So we brought it down the road today!
The sale is Saturday so we have to take the loader to the sale by tomorrow. So we pulled it in the shop this afternoon.
We had to take the loader apart a bit to to it off.
We had some help from the 4020.
We managed to get it off without much trouble.
Then we put it back together and loaded it on the trailer to take up sale tomorrow.
It needs a good cleaning and needs a few repairs and parts replaced. But it runs.
C
cliftonbros89
Missouri
4010 doesnt that date back to the early 60's ? Looks pretty nice, got many hours on it ?
Yes. If I looked up the serial number correctly it would be a ‘61 model. I would imagine it’s been repainted at one time. There’s a few places it seems to have been painted over. I’m not 100% sure how many hours are on it. The land lord didn’t originally own it. He bought it later in his years. I think close to the time that my dad and uncle started farming that place. That’s been sometime ago.
Supposedly when the landlord purchased it he had the engine overhauled. The tach shows over 300 hours. Which I’d say would likely be the amount of hours put on since he bought it and had the engine work done. However, they were the type of crew to just do the minimal on a repair to get by. I think about every hose on the engine looks as though it needs to be replaced. It seems as though there are several areas on the engine where there are fuel and oil leaks. The back end, especially around the PTO and SCV are covered in dirt and residue from oil leaks as well. Now that it has sat in the shop overnight and ran for a good while yesterday there are several oil spots on the floor this morning. So it’s going to definitely need some work!
Very nice!
Thanks!
C
cliftonbros89
Missouri
Started the day off like usual.
Checking on the cows and the calves. Had another new arrival this morning. Have to keep an eye on yet another.
Did a few other jobs this morning.
Next week is the annual trip for my sister’s preschool to come to the farm. I’m way behind on that. But I got one things prepped today.
I pulled the 8400 in the shop and started getting it cleaned up. Washed, waxed, cab detailed. It’s ready to go.
Oddly enough there isn’t really any difference between the before and after picture.
But it cleaned up fairly well. Not that it will last long...
So since I switched things around and moved things I knew dad would get aggravated trying to find things I moved. Especially, the things I moved over to the new supply cart.
So I finally found a use for those magnets I grabbed with the stuff I got from the airport back last year. So with those and the label maker I’ve got some things labeled to make it easier to find. Plus with the magnets if something is moved the label can be moved I need to find some more of these in green.
I pulled the 8400 out and pulled the 7510 in.
It’s dirty and needs a wash. But it really needs to be serviced. So I got things ready to go to start working on it by tomorrow hopefully.
FTWingRiders
Central Ma
Somehow this thread gets away from me, then suddenly I've got 3 pages to catch up on! Thanks for keeping us all in the loop.. at least we can observe, without being in the way and ******* you off!! LOL!
Sorry about the cows, always sucked when we lost a calf. Glad to see that young one doing good!
C
cliftonbros89
Missouri
Thanks!
Nice looking 4010. It will be interesting to see what the loader brings - not much around here.
I doubt it’ll bring much. Dad said he’s betting it’ll only bring $200. I said $300-$400. There isn’t much to the thing. Plus it was really only made to use with the bale spear that was on it. It be hard to find a bucket to work it.
