had to use 11/32 for the first time yesterday
zktk01
KY
I was installing some telco gear at work. usually everything is 5/16, 3/8, 7/16, or 1/2. I was shocked they used such an odd size I didn't have my metrics with me will try a 9mm see if it was actually that size which might be even more odd.
BroncoAZ
I just purchased a Wrightgrip SAE set that didn’t include 11/32” because they don’t make it. I already planned to keep my old Craftsman RP 11/32” just in case.
jayrush13
Lebanon Oregon
Yep use 11/32 nut driver all the time dealing with electrical equipment. Especially nuts in the small j-boxes on motors and ballast nuts.
jd_1138
NE Ohio
SAE stuff is so cheap, may as well get a list of all the SAE sizes and have every size on hand even if it's an off brand.
bonneyman
Desert SW
+3 on electrical work. Sockets short and deep, wrenches shorty and standard. keeping my eyes peeled for an XL wrench. Sometimes a motor bracket uses the motor end bolt for support, and the only sane way to get it off is with a wrench.
You can always tell if the previous guy was a Vise-Grip tech.:mad:
dr_clyde
Holland, MI
Just realized I don't have this in my wrench and nut-driver selection. I do run into #8 screws pretty often.
Just texted my SO dealer to remedy that problem. Thanks GJ...
Provincial
Near Salem, OR
11/32 is 0.3438 and 9mm is 0.3543, so a 9mm is about 0.010 larger. Close enough so you Metric types shouldn't have to buy another tool!
samss
Conway, AR
Like jayrush13 and ecotec, I use 11/32 often enough to have a wrench and driver in my backpack. Who else besides me got fed up looking for a 1/4 hex drive hollow shaft bit and just made their own?
tanukiboy
Japan
But 9mm is also an unusual size. It isn't included in the ANSI/ISO, JIS, or DIN standards, so is often skipped in metric wrench/socket/bit sets. (I know because I just had to track some down and buy them separately!) :willy_nil
