Project 2501
First job doing copper this large. Yeah, I had a few pin hole leaks. I'm not going to pretend I'm the baddest fitter alive but I'm pretty darn happy with how things turned out..
Did you nitrogen purge while sweating it so the inside wouldnt oxidize?
Are the top pics. soft solder? That's the problem with the brazing alloys the pipe gets ruined from the heat.
Good looking joints Project 2501,
When you get bigger than 2", it separates the men from the boys.
If it was med gas, refrigeration, lube or any clean product line, a purge is a necessity, but not a water service.
Brazing does not ruin the pipe, it just anneals it and makes it scale.
With the cost of copper, I'm surprised the contractor opted to run the service in copper.
Must have been a spec or code calling for copper?
One last thing, on 4" and larger it is nice to have two torches on it, one helping preheat and one brazing or soldering. Not a necessity but helps with speed and quality.
Well done and thanks for sharing
Royce
Yes to all of the above. And thank you for the pat on the back. Some people claim to have no interest in receiving the approval from fellow tradesman... i on the otherhand need the challenge of keeping up with the pack as it both boosts my confidence when excelling at a task and also drives me to work harder if and when I fail..
the sweating job looks really nice... on the first post....
Well done, we just finished a project doing 4" and smaller using 45% silver brazing filler (customer callout) it makes for a nice looking joint.
Congrats on the test results!
Top pics are soft solder on 6" type L copper tubing and sweated with an acetylene turbo torch using an A32 large bore tip
Thank u sir..
Side note.. the second set of pics are supposed to look like that.. I didn't go hog wild with the torch
A32
I own one of those hot air balloon inflating torches, only because I got it cheap. The thing damned near requires hearing protection to use, but yeah, I couldn't picture using anything less for that job.
So you did that all with a B cylinder? ;P
Yes, all of the soft solder sweating was dont with a b tank with acetylene and turbo torch with that gigantic a32 tip. Even with earplugs it still sounds like a jet engine.
The sil-fos brazing was done with an oxy/acetylene rig and rosebud tip. Two torches would have been nice. You can see from the bumpy texture of the joint that I was having temperature issues and producing cold joints. That's when I decided to heat one area longer and almost barbecued the fitting..
But
Thank you for the compliments
They look good to me, for what they are. I'm just stunned that 6" copper was the pipe of choice (because of the astronomical price), but, well done sir!
We always use Bridgit solder. That stuff is great to work with.
We rarely do 6''. Most of the copper work we use Propress. It's great on 4'' IF the customer accepts it and you can afford the price. Propress has really come a long way from their electric gun .
I hear progress is really nice clean work that can be installed much faster than solder joints. I've yet to work with it due to being a pipefitter and not a plumber.
A32
We usually use a full size acetylene tank with a "B " tank to acetylene adapter. Saves going through a bunch of small tanks.
On ProPress[emoji2398] and such.
I have no firsthand experience, but I have seen this become common on the campus I work on. Yes, it has many benefits.
But I question this... the seal is made by an O-ring. The crimp holds the fitting to the pipe.
I've seen many bad O-rings over the years I've worked on things.
I wonder what is going to happen to the O-rings in 50 years?
We used Harris Stay-Silv white fluxThank you sir.
Whats your preference in flux? Everflux or nokorode?
A32
Yeah.. B tanks.. I go through on average about 2 a day. Depends on how many joints I have. Some days I'm just hanging full length runs with couplings so I might do 8 couplings over the course of a work day. But days like today I went through almost three bottles and had to reduce my tip size down to an a14 because the A32 was devouring the acetylene.
My mistake about the whole propress/plumber comment. It's just that the only people I ever hear talking about propress are plumbers, mostly service plumbers.
I am a Union PIPEFITTER, you know the skilled trades guys. Been using it on heating ,chilled water, and condenser water since it came out. Awesome !! It's not cheap . We had a two tray cart with elbows and couplings on it. Was looking at just over $5,000.00 setting there. All 4" copper.
You can really make time with it. We've gotten more work using it especially since there's no open flame. Having propress it what helped get many jobs. Some places require a dedicated fire watch with any open flame, even soldering.
