As the title states - I would like to swap out two 100 amp panels for two 200 amp panels in my two-family house to make wiring extra outlets easier, and also so that I can run a good amount of power to the detatched garage (the main reason).
I WILL be consulting an electrician before I do ANY electrical work; I just like to research things before I hire or ask anyone for help.
So my questions are... Do I need to have someone replace the service entrance cable(s) in order to be safe/legal/legit? Also - a friend mentioned that I might need bigger meters. Do they make 100 amp and 200 amp meters? And how can I tell which ones I have?
Information on what is currently at the house between the circut breaker panels and the incoming power line:
- The wire from the weatherhead to the two meters was recently replaced (within the last 2 years, but before I owned the house). It is about 30 feet long from the weatherhead to the meter box and is labeled:
NEXANS-C ENERGEX 8000 TYPE SE - STYLE: U 600V AA-8000-AL 2/C 4/0 AWG + 1/C 2/0 AWG (UL) E-49786
(I found the spec sheet for this wire here: nexans.us
- The two wires from the two meters to the 100 amp panels both look like they were replaced also. They look to be less than 10 feet in length and are both labeled:
KINGWIRE AA-8000 AL TYPE SE CABLE STYLE U XHHW-2 600 VOLTS 2CDRS #2 1 CDR#4 E73061 (UL)
- I live in Upstate NY (not sure if that matters).
Let me know if there is anything else you need to know... Any help/information you can give me is greatly appreciated! Thank you!
