Hi Eric,
Thanks!
I see I'm not the only PM guy hanging out over on GJ.
Due to the cold and the fact that my forklift is 2.5" taller than my door opening, I haven't had a chance to get the table off to start aligning the saw. I think I'm going to wait for it to warm up a little. I've also been hunting for a nice Reliance XT series or equivalent 3-phase motor on Ebay.
It sounds like you found a nice saw! That's a rarity with the older Do-All's. They seem to end up in fabrication shops, or in the back of repair shops where they get abused. I'm still amazed mine was 98% complete and didn't have a broken trunnion!
Like you, I've been puzzled as to what oil to use. The manual I have for the 3613-1, a slightly later V-36 incarnation, recommends EP 90 gear oil, which is the same stuff that's available in the auto parts store for rear ends. I find it fascinating that the V-36 manual makes a distinction between SAE 40 oil and EP90 gear oil and only recommends the EP90 for use in the V-60. I can't explain that.
However, looking at this chart, the viscosity of SAE 40 engine oil and EP90 gear oil is similar, although EP90 has a wider range of viscosity:
I have another table from Velcon which matches this one closely.
My plan is to run 80W90 multi-grade hypoid gear oil in the transmission, which is readily available at the local auto parts store. Multi-grade oils weren't available in the 40's. Looking at Mobil's 80W90 offering and comparing it to the viscosity chart, it is right in the middle of the SAE 40 engine oil range:
http://www.mobil.com/USA-English/Lub..._LS_80W-90.asp
Anyway, I'm not a tribologist and I don't even play one on TV, but that's my plan! I learned a lot about lubricating oil viscosity measurement while finding and studying the various charts. Lubrication is a fascinating subject.
I recall reading some time back that you're putting a machine shop together. I hope all is going well with your business.
Regards,
John
