Just a tip to you fellow garage nuts wanting to show off your place...
I had some friends over to see The ASYLUM the other day and it was their first time checking it out in person. One of them had been seeing pictures all along the way and mentioned it looked a lot different in “real life” than in the pictures.
So I decided to create a panaramic view of the interior to post in my build thread. I took six pictures circling around the place and used some software to "stitch" them together. I think the results turned out great and help explain the layout. There are several software programs that will do it but I used a Free Trial version of Panaramic Software and it only took a few seconds to select and stitch the pictures together.
Important Tip: If you hold the camera level as you circle around, you don’t get that vertical perspective angle that the program has trouble with. The pictures that I took looking up as I circled didn't turn out so well because it had a problem stitching the various angles together.
Here's what it came up with using the pictures taken from the ground looking up (certainly not quite as good):
These particular pictures were taken standing on a ladder and show the second floor of my shop. I will post the 6 base photos later so you can see what they looked like individually.
