Cleanforce 1400 Pressure washer hose adapter?
ryolse
Colorado
Hello,
I've had a Cleanforce 1400 for the past 16 months and while it works great I do have one dislike about it which is the non universal hose.
Here's my problem I've been pressure washing lots of concrete surfaces around the house this weekend and figured I would get a 12 in. EZ Clean Surface Cleaner with a 9 ft. Power care Pole Kit to make it all go much faster.
The problem is the outer diameter of the M12 15mm outer diameter Pressure Waser hose fitting is larger then the 3/8" inner diameter of the M12 pole kit fitting.
Has anyone had experience with finding an adapter for the 2 ends? The pole extension also came with a quick release adapter.
Here are some better pictures to describe what I'm talking about. This first one is of the Cleanforce hose and the spray gun it comes with.
Here's the hose with the pole extension.
Thanks for any help you can give.
smuniga
Just had the same issue, here is my solution. I had to by new hose and an adapter, see pics.
Chino815
Behind Home
I know this is an old thread, but I found it useful to me.
I also have the Clean Force 1400 that I purchased at Home Depot circa 2012. Instead of replacing the entire gun, you can use a Bosch quick connection.
I've pasted an image below of the adapter I purchased for Amazon, but I'm not sure if it will show up, hopefully it does.
It fits right into where the CF1400 lance connects into the gun. From there a variety of quick connection accessories like foam guns and nozzles will fit perfectly.
I'm using an inexpensive foam gun from Amazon ($15) with a 1.1mm orifice, that seems to work better with the lower pressure of the CF1400.
usabrit88
do not have one
If possible could you provide part numbers and source for all the items in your pictures, thanks, John
