Please educate me on casters
gemniii
Fulton, Ms
I've a number of rolling work cabinets (and growing):
View media item 91058
that I share between a number of shops:
View media item 90149each shop has good concrete floors inside.
But as you can see I've got to traverse some rough asphalt to go from shop to shop. And with the rattling I'm concerned about breaking a wheel.
What would be a good size and material for some good inexpensive casters to roll this stuff about?
/edit - this is in northern Mississippi, so if there is snow I don't go. Average ANNUAL snowfall 2"
Uncle Dave
Just changing castors is going to be a fair amount of effort.
Good castors and cheap castors are very different things. Try ebay.
cdestuck
Altoona, Pa
The larger the wheel the better, smoother, and easier it will be to push. Aside from that, the higher the weight capacity, the better.
scooby074
Nova Scotia
Pit boxes are what you want. At the plant I used to work at, we had many shop made ones to pull from building to building. Good tires (not casters) are required. We used small car tires and "donut" spares. We pulled ours with forklifts. I dont know how youd pull it without something powered over any distance if there were any amount of tools in it.
ard
Sierra Foothills... California
How does wheel size and width impact performance?
How does hardness of the wheel impact performance? Given the same weight rating is a harder or softer wheel better?
SundayFunday
Mn
Here's a good quick read on casters along with every variety for sale.
McMaster isn't the cheapest supplier, but their catalog is a great reference for just about anything hardware related.
can't post link. see next post.
Jazz1
Thunder Bay On.
A set of 4 would be handy under tool cabinet, not rough surface though
Harper Handy Casters
tarmy
Nor Cal
Don’t buy cheap casters...good ones will not flat spot and can swivel and lock too...
ER Wagner or RWM make good ones...
2gslse
I dont know how much weight but any thoughts to the power unit from a wheelchair?
ATC
VA
The vibrations from hard casters rolling over that type of surface over a period of time can destroy anything they are attached to. Cracked sheetmetal, broken spot welds, can loosen nuts/bolts, etc...
You need rubber tires. Foam filled, or solid rubber would be better. Pneumatic is another good choice behind those.
metalmagpie
Seattle
Bigger casters roll easier.
You need to learn how to weld.
Casters can be rigid, swivel, or swivel that locks to 1 direction.
Casters can have brakes or not.
Real good casters swivel but have swivel lock, and they have brakes.
Mr.N
Mpls, MN
I have a set of 9" on a heavy 24"x36" cabinet... too tipsy from the swivel the larger caters make, I am looking at going to 5"
When going straight, they roll very nice.
