Show us your cool, "old" drill press
xman_charl
my drill press
2 1/2 hp 90 volt DC
use to have 2 pulleys, now three
got extra pulley from grizzly
[/url][/IMG]
[/url][/IMG]
Charl
bubinga
Here is a couple of mine. Recently picked up this small Atlas 1010 for $50, with a good cleaning she purrs like a kitten. Wasn't planning on keeping it but it is so sweet. The other is a Craftsman floor model that I fitted with a Craftsman variable speed/reversible motor and remote switch. Fun stuff....
Is that A D/C Motor?
Wondering how they do the speed control.
bubinga
Curiosity has me wondering why?
I can see that it's a very basic dp apart from the radial arm, but otherwise?
Sent from my SM-G930T using Tapatalk
Here is a Picture in case it disappears. Asking $325.00.
I could of got one guy on CL offered it to me for $50.00.
I never had or used one, But have heard of some flex in the Arm.
I heard they are OK for woodworking though.
tool_scrounge
Southern California
A DC motor runs off direct current, like what you would get out of a battery.
DC motor are relatively easy to control speed, you just vary the voltage (yes I am over simplifying it a bit).
Some folks scrounge used treadmills as they often have a DC motor and a variable speed controller that plugs into a normal AC wall outlet. This can be a low cost solution.
I scrounge craigslist and ebay for low cost industrial DC motors and controllers. The ability to twist a knob to change speeds on a drill press instead of moving belts on pulleys is pretty nice. Sometimes you still may want to change belt positions, but not often.
hsvtoolfool
Rocket City USA
i came across this for free. not sure if it is worth anything
That is called a "post drill". You'd mount in to a post in your barn or forge. They were especially handy for misc farm duties and blacksmiths.
Yours looks like it may be a "Buffalo Forge" or "Champion" which is missing the main handle on the right side and someone added a handle directly to the flywheel. Or maybe that's how it came. There are a hundred brands of post drills.
These run about $50 to $100 in my region. There may be certain makes and models worth more, but post drills are not an area of special interest to me. I got one in the garage just because they're fun. I should move it to the kitchen and tell people it's an antique apple peeler.
I've had Zero issues with my Treadmill motor conversion at any speed. the motor will do better than 4K RPM without a load, at slow speeds I can go much slower than needed, and it self compensates for load, (load increases it applies more power automatically)
The key is the controller. A brute force rheostat can't do what the modern controllers can do.
This is my build thread and after its done there is a vid with me hand loading the chuck at VERY slow speeds. I've seen it do the same with real work pieces.
http://www.garagejournal.com/forum/showthread.php?t=159224
6PTsocket
So they didn't work too well.
I read where they are not made to run at low speed for very long a time.
Were you using a pulse type speed controller or a simple triac type, which is similar to what is in a lamp dimmer and has the exact problem you describe. There is almost no power low end and no compensation for load.
bubinga
How ever it comes from the factory.
Thats a Motor set up sears used to sell.
bubinga
Good Deal!!! Have to read it,
No, I love mine.
Once I get electric to the albeit small Garage here, and Make Room, The Wards/Logan 10"
Is next.
What do you think of the KBIC 120 controllers?
I have a few here, Have not really used one yet, other than fooling around on the bench.
wmsheaf
Cocolamus, Pennsylvania
She's in solid condition, but hasn't been run for maybe 20 years. I'm hoping I'll find some pointers on how to get it cleaned, lubricated and doing work once again in my shop.
No, I love mine.
Is next.
Sorry I missed the Q on the KBIC controllers - but no opinion as I don'y know anything bout them. Sorry.
Craptain
Tampa Bay FL
Lovely machine. And the center pulley is invaluable. Best source for information and tips is the Craftsman drill press thread. I think Frank Lee has rebuilt every model of Craftsman dp.
bubinga
Oh Thanks Outlaws!
Do anything with it yet William?
I saw it on the facebook group too.
DaveT
St. Louis area
Just got this old Atlas/Craftsman 101.24820 drill press with some nice extras. A scarce table lift and the slow speed extra pulley setup.
My question is about the Palmgren rotary cross slide. Any chance it came with the drill press originally?
It bolts right on without any extra holes, and has obviously been on there a long time - maybe since the press was new.
I did some Google searches, but couldn't find that exact model or much other info. Did notice some other similar drill presses in this thread.
What do you guys think?
How much info did you find out about your drill press? I just purchased one today with the same model number. Any info like date sold would be great.
OccupantRJ
Eastern North Carolina
Here is my 20” Walker Turner I recently finished a refurb on. It was given to me by the company I worked at before retiring.
Mike W.
Rotex turret punch, 18 stations, 1/8 through 2 inches. I recently refurbed that also. Acquiring used machines and doing rebuilds to them is my main hobby these days.
Never seen one that small! Place I worked for 18 years had the large CNC Amadas, looks like the same principle tho
Sent from my Moto Z (2) using Tapatalk
billarch1960
Tucson, Arizona
I bought this at a garage sale for $50 and proceeded to strip it down and start rebuilding it.
billarch1960
Tucson, Arizona
I really love this Walker Turner DP-101. I need to fabricate a base because this one is broken and I need to get a motor for it.
exmaxima1
Midwest
Those are nice presses. I had same model a few years ago, and can tell you that the missing spindle cover will cost you more than the rest of the DP! Good luck!
