Farmer09
What is a good mig Welder that uses 220 an that will weld with 0.45 wire I’m looking for a used welder but what would I be looking for size wise what welder number. Thanks
I love my little Hobart 140.
Ditto, I use both 0.30 and 0.35 flux wire.
I’m useingbit on farm equipment I like how it makes a big puddle an covers more. I have a millermatic 150 220 power source it just want hardly burn the 0.35 wire as good but I’m also used to the Lincoln dc600 at my work that’s burns really hot but it’s also a 3 phase Welder. Just trying to find a good shop welder that will weld what ever I wanna weld when I wanna weld it an not have to worry will it hole I also have a pipe liner lincoln sa200 for my feild work but a good mig is hard to beat thanks for ur opinions guys I like to no what other ppl think about it. Thanks
The Miller XMT 350 CC/CV at school has pulse.
All this talk.........I'm going to have to try it out Monday during stick class, before I do my stick assignments.
Bill
That XMT will need the Optima pendant to run pulse with a wire feeder.
I realize it's a ********* but I am with the guys say that this isn't a candidate for a 7000$ machine. Likely doesn't need it either. That kind of thing is amateur advice from professional welder.
With careful shopping you should be able to get a MM252 or L256 for right at or under $2k. More reasonable than a 350P LOL
I love the arc quality on my Lincoln 256, and a 252 is just as good or better
Just saw a 350p go for $1800 at auction here locally. 252s went higher, as they are more known to the home shop guys. Industrial grade machines are very reasonable used if you are patient and know what they are worth.
