bad_idea
I am in process of building my 30x40x12 detached garage in my yard. I paid a designer to draw a set of plans for the building. It covered all of the pertinent details for framing and sheathing my building - anchor bolt spacing and size, nailing patterns, material size for studs and sheathing, header material and assembly, etc. I work from blueprints on a daily basis on Navy ships and can build just about anything with a set of prints.
Is there a service out there that will provide a set of plans that spec out all of the needed materials to install a 100 amp sub panel fed from the main panel on the side of my house? All of the codes specific to my install in the general notes (cable clamp requirements, GFCI requirements, etc). A couple wiring diagrams to show the routing of cable for each circuit.
