HoldenHR1966; thanks for the reply. I also believe that this S4 is from the 1930s. When I flipped it over, 3 large balls [5/16 dia.] and 1 small ball [7/32 dia.] fell out. While up-side-down I hit the back of the hydraulic case several times; no more balls fell out. I have an instructions and repair manual for Blackhawk S-4-1 & S-4-3 4 ton jacks that shows a parts diagram including part placement If you look at my last photo, the top hole contains a spring loaded pointed plunger; the next hole contains a large ball and a rod connected to the screw-in top; the third hole contains a small ball, a large ball, and a rod connected to a hex head nut; and the last hole [4th] contains a large ball followed by a rod connected to a screw-in top.
I used this configuration when assembling the jack. It did not work. I then removed the top, drained the oil, and then noticed that the screw on hole 2 did not seal against the copper washer. I then unscrewed the rod on hole 4 and found that the hole 4 rod was longer than the hole 2 rod [2 1/2 inches verses 2 inches]. The parts diagram for the S-4-1/3 shows these rods to have the same length and same part number [27 S4.186G]. The last thing I tried was to place the small ball in hole 2 [the hole 2 rod sealed properly], left only the large ball in hole 3, and put 2 large balls in hole 4 [it sealed properly]. The jack did not work. I had this jack over 40 years and the only other maintenance I've done was to tighten the gland nuts about 30 years ago. Before I started this repair the jack was working, but was sluggish and leaking oil. I certainly appreciate any help you can give.
Regards; Fred
