Stripped hex head bolt - removal?
jdewitt
Here!
Cut a slot in it with a cutoff wheel and use a large flat screwdriver that fits snugly. This will obviously ruin the outer flange / washer.
stickshift
northeastern US
They might have some sort of loctite on it, pretty common on exercise equipment.
Allen bolts everywhere but they feel like they are made of cheese.
:bowdown:
That must be it!
Let me grab my heat gun. BRB.
Applied heat and 2 of the pivots were removed. Third pivots got a lot more heat than the first two and the bolts still wouldn't budge and were just starting to strip. Fourth pivot is the one with already partially stripped bolt and that wasn't moving either.
I don't want to apply a lot more heat from a heat gun because of the plastic cover.
So you were right, threadlocker was used, which makes sense - this is commercial gym exercise equipment. For my home use, threadlocker is unnecessary as these bolts are readily accessible and I can check them for tightness every year or two.
stickshift
northeastern US
I personally would use a cut off wheel and make a slot and use a flat head, but drill it out if you want and should just fall apart on you.
I might opt for drilling out so that I can salvage that flange/washer retainer piece, which is apparently no longer available per the gym equipment parts websites.
So when drilling out, the idea is drill out the head and then pull the pivot pin from the other side? How would you get the threaded portion of bolt stuck in the pin out?
kb1982
Kentucky
I would pound a slightly oversized torx bit into it. Unfortunately i have to do this fairly often when doing logo changes on plastic injection molds.
Sent from my LML713DL using Tapatalk
CR888
What worked for me in a similar situation was a spline bit instead of torx. A torx may well do it but I found the finer ribs on a spline bit grabbed much better after tapping it into fastener hex head with a small hammer. The splines really resist slipping and grip in more/multiple places. I found the torx did not 'grab' in enough places and wanted to deform the hex more. But every situation is different, good luck. Here's a pic of a 'spline' bit...
6PTsocket
Try a Grabit screw extractor they are pitched to grab in the shallowest of holes. You won't even have to drill a pilot. I think Lowes may still carry the sets.
bob15
Northeasten, CT
stickshift
northeastern US
If you change your mind Vibra-tite works real well. It doesn't harden and "freeze" a bolt like a thread locker, but rather just keeps it from vibrating loose.
https://www.vibra-tite.com/threadlockers/removable-reusable-threadlockers/vibra-tite-vc-3-threadmate/?cookie-state-change=1553943412374
Thanks for the tip. I have some Vibra-tite that came with a scope, and I never opened it, assuming it was just another threadlocker, and I already had an opened container of blue Loctite. I'll give it a shot.
DSLTRK
PHELAN, CA
I'm thinking it looks like a stainless steel screw, and galled threads .
This.
Unfortunately ss bolts tend to gall and bind if they have been installed awhile. Even if they were torqued correctly.
A slot cut into the head may work but not likely. Every galled ss fastener I've come across acts as a chinese finger and eventually will snap if forced enough.
What I do is slowly drill out the bolt to preserve the internal threading, then re tap using lots of oil.
stickshift
northeastern US
Got the last 2 pivot pins out by hammering a torx wrench into the stripped heads. Even after the first couple of turns, it was still very tight, so there was more than threadlocker holding the threads tight. Does galling increase resistance to loosening even after the bolt has started moving?
Strouty
Southern Maine
Galling is a distortion of the threads, commonly happens when stainless is over tightened. I encounter it often and usually the mess that is made results in breaking the hardware off and I am dealing with 3/8” stuff.
MoonRise
Not quite. :beer:
Galling is when two pieces touch 'well enough' that they actually weld themselves together on a molecular level. Many stainless steel alloys are notorious for doing that, especially if the two pieces are the same alloy and 'clean'. Once the two pieces gall, often the only way that they will come apart is destructivly.
Hence, never-seize. :lol_hitti
