Removing shield from central pneumatic cutoff tool
V
vdotmatrix
Northern Virginia
Does the nut not just unscrew? I seem to recall these cutoff tools are pretty straight forward to take apart.
There is just no clearence, clarance, to get a wrench in between the lousy shield and the nut to gain purchase....tought there has to be some magic tool or spell involved....thanks for the response.--mine looks slightly differnt with a dark housing,
Bondo
Greenfield, Maine
Ayuh,..... Is that the Only grinder you've got,..??..??
If so,..... borrow somebody else's, 'n just Cut the damn thing off,....
V
vdotmatrix
Northern Virginia
I have a lot of tools
If it just that simple.i wouldnt be here.....the nut must be >2.25” my largest crescent wrench is too small wtih no room to grab it.. i thought maybe some kind of giant socket wrench but then ...oh never mind...
American Locomotive
Rhode Island
Just grab it with pliers, or make a wrench out of some sheet stock. They likely just have a low profile sheet metal wrench to tighten it in the factory.
Kev442
Wi
Was in a hurry to get at a tight area, cut mine off. At $6.99 with coupon at HF, who cares?
anndel
Hawaii, USA
Go to a bike shop. The techs there have flat wrenches by Park tools that they could help you with.
V
vdotmatrix
Northern Virginia
I just got back home and you have given a big idea. I am going cut a piece of plumbing strap to fit the circumference with enough extra to grab the ends with vice grips or a stout channel lock and hopefully I can get enough torque to spin this B***ard off! Thank You , I will get right on this!!!
V
vdotmatrix
Northern Virginia
Thank you, that will be my next attempt if I can't make a tool like American Locomotive suggested!!! Bike mechanics have all sorts of specialized tools for wrenching cassettes off wheels and so on!!!
V
vdotmatrix
Northern Virginia
Just use channellocks, it's not complicated
Thanks Chris but like I tried to convey I have have 6 different channel locks and NONE can gain purchase on that ^%$%$#^&& nut. I need to post an image so you cats get an idea of what I am dealing with....Thanks for the response.
V
vdotmatrix
Northern Virginia
I thought these lousy air tools were a POS, 15 years ago when I bought some of them and with a little care and maintenance they have lasted beyond my expectations...I don't need to trash a tool to get multi-purpose from it. I appreciate your help.
V
vdotmatrix
Northern Virginia
Thank you...it is not a grinder, like I said it is a cut-off tool that I want to use for something else, THEN, when I need to, use it again as a cutting tool with the safety shield intact.. Thanks for the response.
V
vdotmatrix
Northern Virginia
Here are some images.
I can't put the thing in a vice for fear of damaging the tool....can't really hold it to wrench the thing off. what a pain.
This thing is just ON THERE.
It will not come off. I think I may just have to buy a dedicated buffer polisher from Eastwood.
Thanks everyone
V
vdotmatrix
Northern Virginia
I see what you mean.. I bought this thing so long ago I dont know what i paid for it.....Mine almost seems nicer that the ones you see on their website today...thanks for the response
mike93lx
Richmond, VA
A cold chisel and a hammer. Should be able to get enough bite to spin it.
Hold it to your bench with some wood working clamps
gungatim
west mich
have you considered that perhaps it is reverse threaded so as to not come loose while in use?
V
vdotmatrix
Northern Virginia
yes , tried that a little yesterday. I will have to get my OPTIVISOR magnifiers on and see if i can see the threads . I tried gently heating the thing with a propane torch. Earlier i add penetrating oil. Thanks for the responses.
anndel
Hawaii, USA
Roger that, I've used my flat Park Tool wrenches to hold the caliper slide pin bolts to remove the caliper bolts on some cars. Good luck!
V
vdotmatrix
Northern Virginia
I am going to look in my bike kit to see what exotic wrenches I have in there. This is a Central Pneumatic Professional series tool...BIG WHUP
evintho
Santa Rosa, CA.
Personally, I'd just cut off the guard with another cutoff wheel (believe me, once you remove the guard you'll never put it back on). Then, you'll have full access to the nut. Chuck the unit in a vise and put the appropriate socket or a pipe wrench on it.
V
vdotmatrix
Northern Virginia
Thanks believe me I have thought about it, but the shield is not there for its good looks on the tool. With the disc coming apart at high rpms, I think they thought it a good idea. thanks for the response!
V
vdotmatrix
Northern Virginia
After a year and a half, i looked up on my pegboard and saw a Ball Hitch Wrench. Lordy lordy, it was like the tool was made for the nut on this tool and it came right off.
V
vdotmatrix
Northern Virginia
[or just buy 4 of these for the same cost:]
Nah.
I just needed to remove that GD nut and finally got it. I have all I need. Cheers
seber
Deep East Tx.
Let us know how that works out. It would strike me as way too high rpm for the purpose. But then I'm spoiled by having an actual buffer. I think it cost $18.
V
vdotmatrix
Northern Virginia
It has been so long since the OP that I had to see why I wanted to remove it in the first place. I have a buffer and all the blocks of grit and so on, But I guess I needed something for spot burnishing or polishing...i simply do not remember. All is well, that ends well!
