Mickey O
I present to you the original dual pawl ratchet with 80 tooth action, the Duro - Chrome 699 (yeah, it's the same ratchet I posted the other day):
Anyhow I was doing some work and needed a ratchet, I grabbed the 699 because I just cleaned it up and it was sitting on top of my tool box. I'm using it and it seems like one of the finest tooth ratchet I have ever used, seemed odd because it's so old. I counted the teeth by rotating it a 1/4 turn and came up with 20, I was surprised. So I looked over at Alloy Artifacts and here is what I found in part:
Anyhow I though it was very interesting and thought others might as well, the bad news, it's "permanently assembled" meaning if I break it I might as well pitch it.
During the 1930s and 40s much effort was devoted to improving ratchet mechanisms, especially for the "round-head" designs with fine-tooth actions. While others looked for ways to make finer teeth, the engineers at Duro Metal Products came up with a strikingly novel idea. Instead of adding more teeth to the gear, they added a second pawl to the mechanism, with the teeth of one pawl offset from the other by half a pitch. Then as the ratchet turned to get a new "bite", the pawls would alternately drop into position, thereby effectively doubling the number of teeth. The inventor W.H. Odlum and collaborators were awarded patent #2,395,681 in 1946.
The dual-pawl action can be heard clearly when the ratchet is turned slowly, with the two pawls making slightly different clicking sounds as they fall into place. The Duro catalogs advertised this as having "80 tooth action" without describing its 40-tooth gear and dual pawls.
One interesting aspect of the construction is that the ratchet has been permanently assembled by compressing flanges in the head. link to full write up at alloy artifacts
