checkthisout
- Joined
- Sep 5, 2008
- Messages
- 5,232
Shipping container for sleeping, cooking etc.
It looks like my setup should be similar to an RV so my plan was as follows.
1) Floating neutral in panel.
2) In the inverter, the Ground and neutral are bonded.
3) The generator I will be using has a floating neutral.
4) All accessible outlets will be GFCI protected.
Questions:
1) Should the battery ground -12V to the shipping container frame?
2) Should there be ground rod(s)?
3) Any foreseeable safety issues with the generator setup (floating neutral in gen and in panel)
4) If I end up using an "all in one" inverter/charger/transfer switch rather than seperate components, any issues with the floating neutral in the panel, bonded neutral in inverter/charger, battery (12V) system grounding and floating neutral in gen?
5) Any issues with grounding the panel to the shipping container?
Questions:
