anythingyoucanimagine
I have some places where stud spacing is not standard 16oc like rest of home. I passed rough before I realized that the f'n framers fucked with a future homeowner (only 4 places I found trash in the stud cavities happen to be only 4 places where stud spacing is off and a royal pain in the balls).
Aren't there plastic end caps made for ent so you can transition nm-b into ent, then back out, or into a box?
Internet folk lore says all kinds of things about putting nm-b into emt. Essentially I want to use it as a big nail plate. These are all less than 48" sections and far enough away from boxes that securing the nm-b isn't an issue.
I have four locations I'm not comfortable with. If I can't run nm-b through ent (edit: I said eNt, I meant eMt) for protection I'll buy some mild steel U-channel, drill holes in it for attachment to studs and notch it for nm-b staples, then run that in strips.
