Another Door Opener Question...
Allstar
Montreal
Hey guys,
I have a 9'9"w x 6'8"h garage door with extension springs. I purchased a Genie Excelerator garage door opener:
http://www.geniecompany.com/GenieCompany.aspx?cid=304
My question is, does the opener have to be installed in the center of the door, or can it be installed closer to one side of the door? I have seen them installed closer to the side, but the doors were equipped with torsion bars. Can the same be done with extension springs??:headscrat
Here's a pic of the door in question:
Sorry for the picture quality, it's all i have available to me right now.
I would like to keep as much clearance as possible seeing how the door is not very high to begin with.
Also does anyone have any experience with the Genie Excelerator??
Thanks
ghnl
Mebane, NC
How far off center are you wanting to install it? If the door is properly balanced (by the springs) it can be installed a few feet off center. It'd be like manually opening the door with a handle off center and should work OK. If you want to put the unit near the edge of the door that could be a problem.
ghnl
Mebane, NC
Better wait for smarter folks than me then. Or get a Liftmaster wall mounted opening & change to torsion spring above the door...
A
Allstar
Montreal
Thanks, but, unfortunately I can't install a jack-shaft opener because I don't have torsion springs and also because I only have about 3" on either side of the door...
Door-Man
lakeside, ca
Ah ok got ya. How are you planning on connecting the arm to the top section if not centered?
Canada
Allstar,
Check in the manual for your opener.
I recently moved my opener over to clear a vehicle on my lift (once I get it installed!).
My manual (and I confirmed with both the opener and door manufacturer) stated I could mount mine up to 4' (48") off center on my 16' wide door.
If your manual doesn't say anything, a quick call or 2 could give you answer you're looking for!
Lane
A
Allstar
Montreal
Allstar,
Lane
Thanks! Looking into it.
GreyOwl
North Las Vegas
IF the door is balanced PROPERLY and side to side clearances set to minimums there is no problem putting the opener to one side or the other. When you open the door manually do you always lift it from the center? Most people will lift the door from where it is most convenient (center or side). The opener is just an assist and if everything is adjusted correctly you should be able to open or close the door w/o an operator with just a couple of fingers.
Charles
