Wall colour scheme suggestions welcomed...
Edmonton, Canada
I'm four days out from confirming wall colour(s) for my new garage. Ceiling is painted Dulux "Commercial White" and the walls are primed. Work resumes on the weekend.
I feel way more confident picking car colours, not walls. Any and all suggestions and guidance are welcome!
Garage is 27'-6" inside width and 28'-0" inside depth. Walls are 9'-5" east and west, 15'-3" to peak each side.
I'm covering the curb with an insulated box 8" tall and 3" deep (photo, and you'll need to imagine the insulation in there). This is to insulate and hide the curb, and also provide an above-slab base for cabinets, workbench etc. My vision is to have nothing without wheels touching the floor. Said vision is diametrically opposed to the working garage next door.
Garage purpose is display of one or two cars and project space for a third, also social space for small car club gatherings, grandkid sleepovers, neighborhood parties etc (photo). There will be very little welding, grinding, painting, etc. going on in this building.
I expect the floor to be medium/light grey flecks polyaspartic. I would have preferred an equally-durable clear-coat over the natural concrete, but there doesn't seem to be an option for this.
There will be a high shelf on the south wall between the upper and lower windows. This is the project car bay. Also another high shelf on the west wall above the two windows, with lighting underneath for the workbench below. I don't expect much additional shelving other than some attached to the north wall plywood around the electrical panel for a jack, stands, battery charger, fluids etc.
Outside the bathroom against the north wall is a sink, small counter, bar fridge and coffee station (either that or an I.V. drip).
I have an 87"x 26" 16 ga stainless work bench top for the west wall. This has a 4" stainless backsplash that I would position just below the electrical boxes which start 42" up from the slab.
So if there was to be a horizontal stripe, I expect it it would be 5-1/4" tall to match the combined height of the workbench+backsplash, and positioned similarly about 41" above the slab. Seems a higher stripe might work better though with the higher peaked ceilings.
The cars most often in this garage are red. The project car will be red in a few years. The equipment going in is no particular colour; I have some red, blue, black, stainless and white. There will be no man-cavey decor - my preference is artifacts, old maps, old posters, photos of the cars in action and so on.
My unimaginative inclination for colours is a light/medium grey floor; a medium grey for the curb covers, the horizontal band, the window trim, and the shelves around the electrical panel; and the walls would be white above and light grey below the horizontal band.
Typing that out highlights to me how boring all that grey sounds. This is a real opportunity to do something more imaginative. I've googled for garage wall ideas and read a number of GJ threads on same.
Comments, suggestions, examples?? Thanks in Advance
fourbyford
North Idaho... almost Canada!
...horizontal band same color as the cars?? I'm not sure I would cover the curb with wood (unless you're going for more insulation)... maybe just smooth it up a bit and paint same color as floor
...D
anythingyoucanimagine
New England
I am in the process of cutting baseboards for my garage. I'm using plastic (pvc) so it won't rot or get nasty when something leaks into it (or because it's plastic it'll just melt).
I wouldn't put non-PT on a slab like that pic.
glentre
Gloucester, Virginia
Suggest you visit the Gallery section of this forum. There are tons of photos and conversations on actual garages built and finished by members. You will get plenty of ideas.
Glen
tff
Greer, SC
Recently painted mine. Here's the result. The white portion of the walls is Sherwin Williams 'Ethereal White'. I forget the gray/blue color name (but can look it up). And for context, a Guards Red car and a Meteor Grey car :) .
3onthetree
My opinion is your instincts are right on. Grey might be boring in an empty garage, but you don't want the focus on the walls once the cars, equipment, and decor is in. Grey also goes well with all the other colors you mentioned. I could see the horizontal band being another color like red or blue as well if you want a little excitement.
You could even extend the grey to the top plate since there's enough windows and overhead doors to break up that color and then accentuate the "drama" of the open ceiling.
rnixon
I too had a tough time choosing colors for my garage , until i said "the heck with it" and decided to just "wing it" and pick colors I like ,without regard to weather they went together
I knew what I didn't want, and that was a white ceiling, two tone grey walls with a red stripe and definitely no black&white checkered floor
I had no idea what the end result would look like because I was making it up as I went along. Here's what it was starting out,and what it looks like now. The floor will be a high gloss acid stain green and the lift going in next month is black
Maybe the colors don't go together or the black trim is not to anyone else' liking I don't care, I like it.
bdbecker
Iowa
I'd recommend a light, neutral tan color (like in rnixon's first pic) for the walls and leave the ceilings white. My folks recently did this scheme in their attached garage it it turned out really nice. Not boring and sterile like all white, not busy like two tones with stripes.
...I knew what I didn't want, and that was a white ceiling, two tone grey walls with a red stripe and definitely no black&white checkered floor...
I'm glad there's at least one other person on GJ that shares my distaste for this cliche. Beautiful space you have rnixon!
John in OH
SE Ohio & Eastern Virginia
Typically, most guys have some "theme" in mind ... such as a sports team, school colors, match to favorite car, etc. When I painted my shop I had a vague idea of what I wanted but couldn't get the colors "right" until I got the wife involved. She was able to help me pull it together in a scheme that I'm really happy with. Check out my paint selection and subsequent painting process in my built thread starting with with post #111 at:
https://www.garagejournal.com/forum/showthread.php?t=98038&page=6
Your interior painting will really add a "wow" impact to your project!
