Motorman55
Info: House located in south New Jersey, 1 car attached garage. HOA.
Panel Date: 6/4/1979
Main Breaker Rated: 150 Amp
1- 'Dedicated' 15 amp breaker to the garage. (Outlined in Red) for a single duplex outlet located on the front wall of the garage. The wall adjoins the kitchen.
1- 'Shared' 15 amp breaker to the garage (Outlined in Yellow) for the garage door opener, one wall switch wired to two ceiling mounted single duplex outlets and an original single light bulb socket. This breaker is shared with all the 4 ceiling pot lights and 2 ceiling fans in the kitchen.
1- 20 amp breaker for the outdoor single duplex outlet located on the rear of the house.
1- 20 amp breaker for the outdoor single duplex outlet located on the front of the house.
4- single blanks remaining in the breaker panel.
NEED:
2- single duplex outlets, (1 to the long outside wall and 1 to the long inside attached wall.)
1- 240v 1ph outlet for a compressor to the outside wall near the garage door.
Questions:
1. Can I achieve this with the current panel? If so what's the best way to proceed?
2. Do I need to have the panel upgraded to 200 amp?
3. What problems could I expect with regard to permits, electrical inspector?
4. What am I looking at as far as costs? Easy access to attic above garage.
Any advice appreciated. Thanks in advance.
NEED:
Questions:
