Compression Fitting
Levaughn
NY
Could someone tell me the size of this compression fitting and where I can get another one? The micrometer says the hose size is -4.63mm. Thanks in advance.
MattT
4.63mm is probably 3/16" tubing. But zero your caliper properly and recheck the measurement.
L
Levaughn
NY
I zeroed the micrometer and it still said the same thing. I did a computer search a found the replace hose which says the size is 4mm.
Skin
Boston
Worst case just match the thread and replace the run with copper.
L
Levaughn
NY
The tube is the line for the Argon hook up on a Bokrand gmbh pocket mig, 110v. I have two of them. One doesn't have the end to go to the tank like the one in the picture.
L
Levaughn
NY
I cleaned up the fitting and it has the name "Sistem" on it. I have to get a 4mm fitting. Thanks again to all.
MattT
It's unusual for tubing to swell that much. Best to order new tubing because you'll have a heck of a time getting that old tubing into a new fitting.
L
Levaughn
NY
All I see is "Sistem" stamped on the connector. Someone cut the connector off the end of that small white hose that goes to the tank. I took the trigger apart and the same fitting is on the end of the trigger.
