longshanks
- Joined
- Feb 16, 2010
- Messages
- 6
Hello from Northern Canada eh!
I've already done a bunch of searching and reading on this site, and although I have some ideas on what I might do next to reduce my garage humidity, I thought I'd post some details and see if any of you are able to help.
The attached garage is 20x20 with a floating concrete slab. We bought the house a year ago so I can't tell you if the slab has vapour barrier under it or not. There are insulated concrete form walls surrounding the garage, with a gap of about 1/2" between the edges of the slab and the ICFs. The ceiling is covered with at least 18" of blown in insulation, and the house has 2x6 walls, well insulated. Both the main door and the man door are reasonably well insulated.
When we bought the house, there were creepy dark mold stains in the corner of the garage on the gyproc, and my humidistat tells me that the garage is at about 75% humidity on average. The car and snowblower live in there, unless I'm taking on a woodworking project. If you think you can talk mrs. into parking her car outside, you have an open invitation. I'll put on the popcorn
I just sunk a fair amount of $$ into a vented 45K BTU natural gas heater, and I have it set to keep the garage temperature above 5 degrees celsius or so. Winter temperatures here probably average around -8 degrees celsius. The forced air heater has a fan that comes on when the thing cycles. I had to cut a 4" vent through my wall for intake air. This heater warms the place up quickly, but I'm concerned about the cost of running it constantly.
Any ideas on what I should be doing next? Right now I'm guessing the potential solutions are to either
a) stop being so cheap and turn up the heater
b) try sealing the slab with some sort of a silicate deep sealer
c) buy a de-humidifier
d) put my foot down and tell mrs. to park her car in the snow bank
standing by...
cheers
standing by...
cheers
